Trubo fitment?
Old Jan 12, 2006 | 12:57 PM
EJ8 GSR-T's Avatar
Default Trubo fitment?
So im posting here becuase i get better resoponce than in the FI forum my question is....my turbo wont fit in right, and i want to know if anyone has any imput. THe waistgate and air output (where the turbo sends out air to the intercooler) hit the radiator fan, and i dont think a slim fan would help enought because the air output on the turbo also hits some of the ac lines...any ideas? (i need to keep ac)
Old Jan 12, 2006 | 01:01 PM
EK k kay's Avatar
Default Re: Trubo fitment? (userdead626)
Clock the turbo and rotate the compressor housing so that the outlet to the intercooler does not hit anything. A slim fan would probably help.
Old Jan 12, 2006 | 01:04 PM
saywhat's Avatar
Default Re: Trubo fitment? (EK k kay)
or go externally gated.
Old Jan 12, 2006 | 01:20 PM
1337 Si's Avatar
Default Re: Trubo fitment? (saywhat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saywhat &raquo;</TD></TR><TR><TD CLASS="quote">or go externally gated.</TD></TR></TABLE>
Word
Old Jan 12, 2006 | 01:47 PM
Earthworm Jim's Avatar
Old Jan 12, 2006 | 02:11 PM
tallyturbo's Avatar
Default Re: Trubo fitment? (The_General)
ill post some pics later if i remember but what i did was take the rad loose and twist it sideways a little bit and then put a slim fan behind the rad
Old Jan 12, 2006 | 02:17 PM
Ricey McRicerton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">Clock the turbo and rotate the compressor housing so that the outlet to the intercooler does not hit anything. A slim fan would probably help.</TD></TR></TABLE>
Thats what I was thinking.
Old Jan 12, 2006 | 03:07 PM
Sikocivic's Avatar
Just notch the plastic fan shroud to clear the wastegate.
Old Jan 12, 2006 | 04:33 PM
Stars's Avatar
I'm a Jackass
Default Re: Trubo fitment? (Sikocivic)
you don't need ac.. come on..
Old Jan 12, 2006 | 05:06 PM
jin05's Avatar
go with aftermarket electrical fan. it should work
Old Jan 12, 2006 | 05:39 PM
EJ8 GSR-T's Avatar
Default Re: Trubo fitment? (Ricey McRicerton)
What does "clock the turbo mean" and how do you rotate the compressor housing
how?
Modified by userdead626 at 9:44 PM 1/12/2006
Old Jan 12, 2006 | 07:04 PM
EJ8 GSR-T's Avatar
The prob. is this ******* mistu t25 the air output or what not faces the same way as the intake part...the output needs to face down
Old Jan 13, 2006 | 11:45 AM
tallyturbo's Avatar
unbolt the 6 or so bolts on the housing and just turn it to fit.
EJ8 GSR-T
May 30, 2008 12:11 AM
lacking vtec
Feb 13, 2006 01:13 PM
eg6nes
Feb 18, 2005 02:31 PM
ownedbyvtec
Aug 20, 2004 11:48 AM
B18Flip
Jul 4, 2004 06:32 PM
