rpm limit
Old Jan 12, 2006 | 08:31 AM
blk89crx's Avatar
Default rpm limit
i have a 89 si and was getting a code 4. I replaced the distributor and cleared the code still didn't work. Then i put in a new ecu and cleared the code still didn't work does any one have any idea of what i could try. the motor is all stock
Old Jan 12, 2006 | 11:51 AM
$racer1's Avatar
Default Re: rpm limit (blk89crx)
are you talking about the crank angle sensor?
Old Jan 24, 2006 | 12:36 PM
blk89crx's Avatar
Default Re: rpm limit ($racer1)
yeah that is the code that i am getting
bump
Old Jan 24, 2006 | 11:28 PM
x_outlaw_x's Avatar
you have to splice the wire for that sensor into the other postion sensor...forgot what its called, its the one in the distributor
Old Jan 26, 2006 | 08:05 AM
blk89crx's Avatar
Default Re: (x_outlaw_x)
do i have to do this in the distributor or the ecu?
Old Jan 26, 2006 | 08:06 AM
blk89crx's Avatar
Default Re: (blk89crx)
up
Old Jan 26, 2006 | 09:11 AM
x_outlaw_x's Avatar
sorry i misread the post, i thought you put a diferent engine in and it wasnt running right...but if that sensor is bad you have to find out what color the wire is for that sensor, then just splice into that wire anywhere
mightymaxgst
Nov 27, 2006 10:28 AM
KURUPTinc
Oct 28, 2005 10:17 AM
underage
Jul 13, 2005 02:33 PM
Airbag Club
11
Mar 10, 2005 03:05 PM
