what can i expect with this setup?
Old Jan 11, 2006 | 06:57 PM
buttsneeze's Avatar
Default what can i expect with this setup?
ls/vtec, bottom end fully built b18b except for stock sleeves, top end b16a w/ jdm type r cams and aftermarket springs & retainers. Here's the question. What can i expect if i max out my drag gen III turbo kit to 25psi on this setup on neptune? I would go ahead and change the manifold and turbo to something bigger and better, but i'm strapped for cash at this point. If what i have now can make me happy, then why change? Oh, here's my second question. Will i be able to push 25psi on pump gas? And i'm not sure of the turbo specs, but it's whatever's standard with the drag gen III turbo kits.
Old Jan 11, 2006 | 07:00 PM
B18 CYA's Avatar
391.5 whp 258.9 ft lbs tq
Old Jan 11, 2006 | 07:02 PM
MOUNTAINGARAGE's Avatar
Default Re: (B18 CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">391.5 whp 258.9 ft lbs tq</TD></TR></TABLE>
I was thinking 390.1 whp 265.7 ft lbs.
Old Jan 11, 2006 | 07:05 PM
buttsneeze's Avatar
funny......i know you guys hate this type of post, but i'm just not ready to spend a sh*t load of money on anther turbo manifold and turbo (and radiator i might add). i just wanna see what some of you guys think because i'm all about other people's opinions.......just trying to see if i'm just going the totally wrong route about this and i should just cringe up and spend more money........
Old Jan 12, 2006 | 02:01 PM
buttsneeze's Avatar
Default Re: (buttsneeze)
anybody else?
Old Jan 12, 2006 | 04:06 PM
tokesGTR's Avatar
If you arn't ready to spend a shitload of money on a new turbo and manifold, you arn't ready to spend a shitload of money rebuilding your motor and turbo when they both let go when you try and push 25 pounds of boost into the motor on pump gas.
Old Jan 12, 2006 | 04:42 PM
buttsneeze's Avatar
Default Re: (tokes1320)
well then what's the limits on 93 octane as far as boost? If i can push 350whp on pump gas with a huge turbo at like 12psi, then can't i push the same amount of hp on pump with a smaller turbo but at like 25psi? Not to mention, i don't have easy access to anything higher than 93 octane..........
Old Jan 12, 2006 | 04:44 PM
Mr. Vapor's Avatar
i dont even know if your turbo will be any more effective at 25psi than it will be at 15psi if its the stock drag turbo.
Old Jan 12, 2006 | 05:02 PM
buttsneeze's Avatar
Default Re: (Mr. Vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Vapor &raquo;</TD></TR><TR><TD CLASS="quote">i dont even know if your turbo will be any more effective at 25psi than it will be at 15psi if its the stock drag turbo.</TD></TR></TABLE>
why not? drag says it's good up to 26psi and the kit as a whole is good up to 450hp (of course, that's probably crank hp)
still didn't answer my question though.......but to add to your point, the drag turbo probably won't last too long at that type of pressure........
Old Jan 13, 2006 | 04:44 AM
Mr. Vapor's Avatar
well i maxed out my DRAG turbo around 18psi..it just didnt want to make anymore power past that.
SC61 time
Old Jan 13, 2006 | 09:17 AM
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buttsneeze &raquo;</TD></TR><TR><TD CLASS="quote">
still didn't answer my question though.......but to add to your point, the drag turbo probably won't last too long at that type of pressure........</TD></TR></TABLE>
WOW, if you want specific info then @ least give specific info to get it. What compressor side (give us the map)? Don't believe much of what the manufacturers of these mass produced kits put on the specs for these things. And even with the map it would still be a guesstimate.
Old Jan 13, 2006 | 09:26 AM
buttsneeze's Avatar
Default Re: (KeyserSoze)
sorry, i don't know the specs on my turbo.......it's already installed and i can't really read it......not to mention when the shop ordered my kit they just told drag my setup and then i got what i got........THEY don't even know the specs of my turbo.......(not to mention, i'm still a turbo noob, sorry) Kit was ordered for b18b in a crx
dohcdawg
Mar 13, 2005 07:02 AM
My ID says Jeff
Apr 5, 2004 11:21 AM
Wpg-prelude
Feb 24, 2004 10:41 AM
blacksheep
Jun 11, 2002 07:34 AM
