anybodys turbo honda eat WHEEL BEARINGS or just mine
Old Jan 11, 2006 | 05:41 PM
mrbsponge's Avatar
Default anybodys turbo honda eat WHEEL BEARINGS or just mine
hey all, i am having this issue with my turbo civic eating up wheel bearings, now i dont make the most HP in the world and the car does run on slicks when i got to the track, im using DSS axles, and i dont think it has anything to do with it
in the past year i have replaced 2 bearings on each side, does this sound right?
now i just noticed it seems as if i need 2 more, damn!
Old Jan 11, 2006 | 05:58 PM
Infinite Auto's Avatar
Default Re: anybodys turbo honda eat WHEEL BEARINGS or just mine (mrbsponge)
definately think there is a problem there..... I'm on my ~20th honda now and never once replaced a wheel bearing.....yes my car is boosted. good luck though
Old Jan 11, 2006 | 06:01 PM
nsxmatt's Avatar
Sounds like you might be using the wrong axles or the wrong int. shaft. I'd check and see if they are binding.
Old Jan 11, 2006 | 06:04 PM
HYBRID_H@TCH's Avatar
Default Re: anybodys turbo honda eat WHEEL BEARINGS or just mine (nsxmatt)
do you slicks stick out far?
Old Jan 11, 2006 | 06:12 PM
mrbsponge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you might be using the wrong axles or the wrong int. shaft. I'd check and see if they are binding.</TD></TR></TABLE>
it may be my intermediate shaft because, i had to have frank send me a different axle, i think i ended up with the wrong one when i did a few swaps on my own cars a while back
and yes my slicks do stick out a bit, they are 13x8 bogarts, but it os only on the car for a day or so at a time, other than that its on factoy wheels in the garage, or on jackstands, sitting off the ground
RIGHT NOW- when my car is on jackstands with stock honda wheels, i can grab the top of my tire and move the tire and rim about a 1/4 of an inch back and forth
thanks guys
Old Jan 11, 2006 | 08:46 PM
Boostage's Avatar
I know too low of a wheel offset can cause premature wheel bearing wear, or tires that stick way out pass the fender, I belive fwd honda stock offsets are 45mm and everything is balanced for a 45mm offset wheel. I would start there.
rolledthatho
Jan 22, 2011 09:06 AM
94civiccupew/b7
23
Dec 11, 2009 06:27 AM
stealth_EK4
Suspension & Brakes
Aug 21, 2005 09:35 PM
fire7882
May 15, 2002 09:00 PM
