Heater not blowing enough Heat ???
My Heater in my 88 Hatch doesnt seem to blow enough heat....its more of a luke warm.
This is an issue to me, because my windows wont defog.....mainly the drivers window, and with a climate that rains 80% of the time, its definatly an issue.
My 89 Hatch blows just fine, and defogs quite a bit better.
Now all the cables are attached to the heater motor, and the hoses entering the heater core, and leaving the core, are Both hot/warm.
What else could be the issue ? A thermostat should be the issue should it ? The temp gauge is half way up the meter.
Thanks
Brad
Thanks
Brad
I'd check for a coolant leak. I had this happen to me in my CRX. I gradually lost heat over several days because less and less coolant was passing through the heater core. This also meant less coolant to cool the engine, resulting in overheating. I also blew my headgasket. Now my car sits awaiting either a headgasket change or a complete engine swap.
well...I know its not leaking coolent, because there would be this mysterious green liquid running from my car......and I just built my engine, and its got new seals top to bottom, new hoses front to back, and a fresh radiator.
lol I be glad to join you...I cant figure out why my blows only warm too...i replaced the thermo with like a 190...replace heater valve and have brand new heater climate unit...also new wires...I am guessing something in heater box no opening or closing any ideas????
grimview
Jul 22, 2013 03:32 PM
BubLBack
Oct 5, 2006 09:47 PM
zman
Jun 5, 2004 08:58 PM
