which wire is the tach wire on z6 distributor?
Old Jan 11, 2006 | 04:20 PM
97grnrs's Avatar
Default which wire is the tach wire on z6 distributor?
im hooking up my remote start soon but im not sure which wire is the tach signal wire on the dist. is it the blue?
Old Jan 11, 2006 | 04:29 PM
SOHC4life 96's Avatar
Default Re: which wire is the tach wire on z6 distributor? (97grnrs)
Yes, tach lead is always the blue wire.
Old Jan 11, 2006 | 06:11 PM
JSPECSIR's Avatar
Default Re: which wire is the tach wire on z6 distributor? (SOHC4life 96)
why go all the way to the distributor ? tach is on the rear of the drivers strut tower, blue wire in a small plug by itself with a rubber cap. ( tach test connector)
Old Jan 11, 2006 | 06:31 PM
x93coupex's Avatar
Default Re: which wire is the tach wire on z6 distributor? (5THGENSI)
there should be a wire behind the factory cluster also
Old Jan 11, 2006 | 07:07 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5THGENSI &raquo;</TD></TR><TR><TD CLASS="quote">why go all the way to the distributor ?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x93coupex &raquo;</TD></TR><TR><TD CLASS="quote">there should be a <FONT COLOR="blue">blue</FONT> wire behind the factory cluster also</TD></TR></TABLE>
Old Jan 11, 2006 | 07:32 PM
x_outlaw_x's Avatar
go with the blue wire behind the cluster...way cleaner of an install that way
Tyson
40
Jun 4, 2009 04:24 PM
4dooreg-k
11
Jun 23, 2006 12:50 PM
Gonzo_SiR
Oct 29, 2003 10:12 PM
92'gsrhatch
Jun 2, 2003 06:37 PM
civicracer1993
Sep 17, 2002 10:53 PM
