JRSC Setup Tips needed....
If i were to get my zc sohc supercharged with the jrsc. What else would i need? I remember someone telling me to get a map sensor, and a cool thermostat or something i belive? Anything else? Injectors?
ANd what would be a safe PSI to use for a daily driver?
tx
tx
You may need a cooler heat range of spark plugs. You should install a new fuel filter and possilbly a larger fuel pump. If your fuel pump is old and tired this could cause your car to run lean. Run 93 octane. Make sure the the belt is lined up correctly. If not this will cause belt dusting and possilbly belt falure. I had a JRSC on my miata. It worked great. The only problems I really had was the alignment with the belt and belt pulleys which came with the jrsc. The bearing go bad kinda quick. This might not be a problem on honda's.
