turbo oil feed lines
Old Jan 11, 2006 | 03:10 PM
steve96accord's Avatar
Default turbo oil feed lines
where oil return and oil feed go? on a sohc 96 honda accord . does the return line go to the oil pan then the oil feed go to the oil pressure sender under the intake manifold? r where does the lines go? thanks
Old Jan 11, 2006 | 03:52 PM
iam7head's Avatar
Default Re: turbo oil feed lines (steve96accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steve96accord &raquo;</TD></TR><TR><TD CLASS="quote">where oil return and oil feed go? on a sohc 96 honda accord . does the return line go to the oil pan then the oil feed go to the oil pressure sender under the intake manifold? r where does the lines go? thanks</TD></TR></TABLE>
you pretty much got the short and easy way.
alot of people just use a brass T to tap the oil supply line from the sending unit, the return line should up into the oil pan.
the thing about the return line is, the higher you tap it, the less chance it will mess up your seal.(hot oil cant get out fast enough)
Old Jan 12, 2006 | 11:10 AM
twkdCD595's Avatar
Default Re: turbo oil feed lines (iam7head)
Another option for the oil feed line is to use an oil filter adapter and run the feed from it. For example Golden Eagle, Greddy (which I use), etc. all make one that would easily accomidate a feed line, all you would need is a male to male AN / pipe fitting to connect it.
The return (as indicated above) works on gravity to drain the oil to the pan. You would want to make sure you have a smooth run to the pan, with no spot in the line lower the pan (or the welded in return fitting) so oil is not resitricted and/ or backfeed into the line. Otherwise you will end up blowing the seals in the turbocharger.
Have the return fitting welded up as high in the pan as possible so that there will be no blockage by the oil that sits in the pan. You may have to comprimise a little here depending on the return line routing, clearance for everything, location of the turbo (as some manifolds hang the unit pretty low), etc.
Be sure to wash out the pan well before you have it welded up... fire is not fun and contamination of the area to be welded can lead to poor welds.
Old Jan 12, 2006 | 02:31 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: turbo oil feed lines (twkdCD595)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">you pretty much got the short and easy way.
the thing about the return line is, the higher you tap it, the less chance it will mess up your seal.(hot oil cant get out fast enough)</TD></TR></TABLE>
That's how I ran it.
Old Jan 12, 2006 | 03:03 PM
where can i find this oil adapter? an thanks for the help
Old Jan 13, 2006 | 12:02 PM
twkdCD595's Avatar
you might want to shop around for the best price and whatnot, I got mine at the local performance shop for around 60.00 (the greddy unit).
kteller.com has the GE one for about 100.00 (which these are usually more expensive than others)
importparts.com has the AC and Greddy adapters for about 60.00 (and I do believe they will price match if you can find it cheaper).
both sites list them under the cat. of engine and subcatagory of oil coolers and/ or accessories.
gabe768
May 22, 2010 01:18 PM
Dre90
Apr 20, 2010 04:11 PM
killamike0001
Sep 6, 2007 12:22 PM
hackish
May 17, 2004 09:45 AM
TurbothisLS
Sep 11, 2002 09:29 AM
