check out my Euro R dyno numbers
Old Jan 11, 2006 | 03:45 AM
dc2Rgirl's Avatar
Default check out my Euro R dyno numbers
Finally got to the dyno with ITR #4279... results are 211,4 bhp at 8210 rpm and 134,2 ft-lb at 8070 rpm. Btw notice the dyno was done in fifth
Mods are:
- Mugen intake
- SMSP header
- SMSP 300 cell cat
- T1R catback
- Kenji ECU
- ATS clutch
- ATS flywheel
- ATS 3rd+4th+5th (with JDM FD = insane )
Old Jan 11, 2006 | 03:57 AM
Dave_B's Avatar
What does that translate into for us U.S folks?
Old Jan 11, 2006 | 04:00 AM
Pompiuses's Avatar
Default Re: check out my Euro R dyno numbers (dc2Rgirl)
Hey that's nice numbers. Tourqe curve looks good.
Did you dyno the car before you had done any mods to it?
What kind of dyno did you use? I see you have only 165hp at the wheels, so this must be a very strict dyno.
Old Jan 11, 2006 | 04:02 AM
Pompiuses's Avatar
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">What does that translate into for us U.S folks?</TD></TR></TABLE>
My Euro R dynoed 182 at the wheels on a US Mustang dyno with less mods than dc2Rgirl here (only I/H/E). So I'd say dc2Rgirl would have about 200-205whp on a US dynojet.
Old Jan 11, 2006 | 04:03 AM
Dave_B's Avatar
Default Re: (Pompiuses)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote">
My Euro R dynoed 182 at the wheels on a US Mustang dyno with less mods than dc2Rgirl here (only I/H/E). So I'd say this would be about 200-205whp on US dynojet.
200-205 with just intake, header and exhaust? Damn
Old Jan 11, 2006 | 04:11 AM
Back in Black's Avatar
Rather OG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote">My Euro R dynoed 182 at the wheels on a US Mustang dyno with less mods than dc2Rgirl here (only I/H/E).</TD></TR></TABLE>
Hrm...that just doesn't sound right.
At P1, the H2 car put down 165whp on a mustang dyno. This was with a Mugen intake, custom 2.5" exhaust with turn-down, and Toda header. You could probably make more peak power with a Hytech/SMS, but I can't see 17 more, especially with a stock bottom end and stock head.
JMO
Old Jan 11, 2006 | 04:18 AM
Pompiuses's Avatar
Default Re: (Back in Black)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Back in Black &raquo;</TD></TR><TR><TD CLASS="quote">
JMO </TD></TR></TABLE>
Was this a B18C6?
Old Jan 11, 2006 | 04:22 AM
Rather OG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote">Was this a B18C6?
Sorry, I should have clarified. It was a USDM C5, and also had only 10k miles.
Old Jan 11, 2006 | 04:26 AM
Pompiuses's Avatar
Sorry, I should have clarified. It was a USDM C5, and also had only 10k miles.</TD></TR></TABLE>
The C6 should be a bit stronger because of the higher compression (same as JDM 11.1:1). Especially with a chipped ECU.
Old Jan 11, 2006 | 04:27 AM
Rather OG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote">The C6 should be a bit stronger because of the higher compression (same as JDM 11.1:1). Especially with a chipped ECU.
I knew about the higher compression, but I didn't think it would make a 17whp difference, especially on a Mustang. One whp is a bunch on it.
Again, jmo.
Drive on
Old Jan 11, 2006 | 04:39 AM
dc2Rgirl's Avatar
211,4 is the BHP. And 134,2 ft-lb torque.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote">Did you dyno the car before you had done any mods to it?</TD></TR></TABLE>
I will be dynoing it next week without the mods and then I will post it.... It was on a MAHA brake dyno (DIN 70020 corrected). When I went there last year with my other ITR with a catback only and a shitty ECU I got 192,5 bhp (https://honda-tech.com/zerothread?id=1188983). The guy at the dyno told me all the stock R's that have been there read around 185-190 bhp so ya it must be a strict dyno.
Old Jan 11, 2006 | 04:49 AM
Dave_B's Avatar
I know my H2 car will have 11.1 comp ratio due to a mugen head gasket, will also have an SMS header on it along with the SMS race exhaust. The J's racing intake will be on it for now. I'll dyno it once I have everything and see what kind of numbers I get.
Edit: I think I figured it out. you guys dyno the engine at BHP not WHP. We over on this side of the pond are going by WHP, which will be lower than BHP.
Old Jan 11, 2006 | 04:58 AM
Pompiuses's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Edit: I think I figured it out. you guys dyno the engine at BHP not WHP. We over on this side of the pond are going by WHP, which will be lower than BHP.</TD></TR></TABLE>
umm, no..... dc2Rgirl dyned 165whp with an _estimated_ 211hp at the flywheel. Whether that estimate is a good one is debatable.
We just use, for the most part, different dynos than in the US which produces different numbers.
Old Jan 11, 2006 | 05:01 AM
Dave_B's Avatar
Ok, but it's not 211 WHP like Jason and I were thinking. That would be way high with just an intake and exhaust, Mugen/SMS or not. The 165 WHP number is what we go by not the estimated FW HP or BHP of 211. That clears it all up.
Old Jan 11, 2006 | 05:12 AM
Pompiuses's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Ok, but it's not 211 WHP like Jason and I were thinking. That would be way high with just an intake and exhaust, Mugen/SMS or not. The 165 WHP number is what we go by not the estimated FW HP or BHP of 211. That clears it all up. </TD></TR></TABLE>
No, whp and bhp is definately not the same.
But as I tried to explain in my previous posts, the results can be compared with US dynos based on the readings of my R on a US Mustang dyno.
Old Jan 11, 2006 | 05:20 AM
dc2Rgirl's Avatar
I think the dynos are generally different here from the US so it's difficult to compare... what will be nice so see is the comparison with the other chart. In any case 20-22 hp over stock isn't that bad I think...
Old Jan 11, 2006 | 05:21 AM
Dave_B's Avatar
To much cross pond communication interference...
Old Jan 11, 2006 | 05:27 AM
Reid's Avatar
Global Moderator
Default Re: (dc2Rgirl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2Rgirl &raquo;</TD></TR><TR><TD CLASS="quote">In any case 20-22 hp over stock isn't that bad I think...</TD></TR></TABLE>
I don't see any baseline numbers.
Where is the graph of the car in stock form to show a 20 hp gain?
Old Jan 11, 2006 | 05:52 AM
Pompiuses's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2Rgirl &raquo;</TD></TR><TR><TD CLASS="quote">I will be dynoing it next week without the mods and then I will post it.... </TD></TR></TABLE>
It would be cool if you could dyno with and without the Kenji ECU as well, as I'm about to buy one . AF readings would be nice also.
Old Jan 11, 2006 | 06:04 AM
dc2Rgirl's Avatar
Default Re: (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">
Where is the graph of the car in stock form to show a 20 hp gain?</TD></TR></TABLE>
I will be dynoing it stock next week... But to get an idea here is my old graph of my other R without these mods:
Old Jan 11, 2006 | 06:05 AM
dc2Rgirl's Avatar
an idea of the dyno I mean not of what this R will put out stock...no flames please
Old Jan 11, 2006 | 08:11 AM
Valvola's Avatar
I think that you have to trust P/mot, not tha din result...
Air temp. in the first grapich?
Old Jan 27, 2006 | 03:37 PM
WeekH22#2's Avatar
I'm a Jackass
From: who knows.. the shadow knows, CA, United States
Default Re: (Valvola)
man I was hopin to make 150tq, and 200whp, with a JUN ECU. would the car have made more power in 3rd gear "
oh wait a sec are we talking about Euro R motors? wtf
Old Jan 27, 2006 | 07:24 PM
cryptikman's Avatar
Default Re: (WeekH22#2)
Very nice numbers.
Old Jan 27, 2006 | 07:52 PM
H-PIMP's Avatar
Plus you guys have much better fuel available at the pump than we do.
