Rotor Rust
Old Jan 10, 2006 | 11:09 PM
astroxtc's Avatar
Default Rotor Rust
i just picked up a set of rear disc brakes, and the rotors and rust like crazy, any idea how to clean them up? i heard wd40 and a metal sponge works.
Old Jan 10, 2006 | 11:22 PM
nocturnaldragon's Avatar
Default Re: Rotor Rust (astroxtc)
Drive on em for a few minutes, it will clean em right off, its normal for them to rust.
Jerms's Avatar
put them on and drive on them or just buy new ones
Old Jan 10, 2006 | 11:24 PM
Redline96LX's Avatar
* B A N N E D *
surface rust is completely normal. get to 80mph, stop. clean.
Old Jan 10, 2006 | 11:29 PM
4dohs4mohoes's Avatar
Default Re: Rotor Rust (Redline96LX)
If you've ever washed your car and let it sit for a while, you should notice the rotors rust. Its def. OK. Just drive it and hit the brakes. The rust will come right off. No prob. Or if your soooo worried about it, buy new ones.
Old Jan 10, 2006 | 11:46 PM
SOHC4life 96's Avatar
Default Re: Rotor Rust (boo bees)
If it's just surface rust and you are really worried about it, have the rotors turned. If you aren't to worried about it then do like everyone else said and just "brake" them clean. If it's really bad rust, buy new rotors.
Old Jan 11, 2006 | 12:10 AM
99blackcivicSi's Avatar
Default Re: Rotor Rust (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote"> If it's really bad rust, buy new rotors.</TD></TR></TABLE>
measure them then cut them if its bad rust, if they can be cut out great, if not, buy new ones, and i fyou bought them used, hav ethem turned anyway don't know what they went through, then have them measured for runout (if you wanna do things right lol)
if its light surface rust put them on the car and drive them till they stop squeaking. after a rain or something or a misty night, go out and look at the rotors on the car, they rust, its bare metal very vunerable to rust but gets cleaned off all the time, mild oxidation is normal let em ride yo!
Old Jan 11, 2006 | 12:15 AM
WHORE: JDMCoveralls's Avatar
Drive on them or use like brake cleaner and youll be okay....
JDMatters
Old Jan 11, 2006 | 06:13 AM
old man neri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by astroxtc &raquo;</TD></TR><TR><TD CLASS="quote"> i heard wd40 and a metal sponge works.</TD></TR></TABLE>
You want to put lubricant on your brakes???????????
(and yes i know WD40 isn't really a lubricant but I couldn't resist
Jpres927
Apr 1, 2006 11:48 AM
spencedogg
14
Sep 25, 2003 06:43 PM
miksew
Sep 16, 2003 04:58 PM
ACIN
Dec 10, 2001 01:28 PM
