windsheild leak
Old Jan 10, 2006 | 08:26 PM
aaron96civic's Avatar
Default windsheild leak
I have a 96 Civic HB and have just discovered that the floor on the driver's side is extremely wet. It appears that it may be the windsheild or somewhere in the cowl area. Is there common places for these cars to leak in this area?
Thank You
Old Jan 10, 2006 | 09:39 PM
Turbo_y8's Avatar
Default Re: windsheild leak (aaron96civic)
not common but possible, just dump water on it and see if you see leaks, possinle that the windshield gasket is rottena nd leaking
Old Jan 11, 2006 | 12:22 AM
WHORE: JDMCoveralls's Avatar
JDMatters
Old Jan 11, 2006 | 12:58 AM
nocturnaldragon's Avatar
Default Re: windsheild leak (tuck'd98)
Its unlikely the the seal is rotting away on you, there a rubbery kinda stuff, it is possible tho that the thing had just deteriorated, get a tube of windshield glue if that's the problem and remove the trim around the window then put a nice bead around there and make sure not to get any on the paint or your hands cause its a bitch to get off. Let it dry per the directions and put the trim back on. Should take care of your problem.
hbracer93
41
Apr 6, 2022 05:04 AM
JDM_is_overrated
Oct 13, 2008 12:42 PM
pinks11
Oct 17, 2007 02:34 AM
Jhonny Ricer
Nov 28, 2006 07:49 PM
project ak
Oct 5, 2006 04:44 PM
