Windshield star
Old Jan 10, 2006 | 06:19 PM
BLKFLSH's Avatar
Default Windshield star
Anyone have experience fixing windshield nicks. It's very small (star). If there is an easy way, I would like to do it myself. The glass shop says it doesn't need to be fixed, because it did not go all the way through the glass. Damn rocks!
Old Jan 10, 2006 | 08:12 PM
P_Adams's Avatar
Default Re: Windshield star (BLKFLSH)
There are Do-It-Yourself kits out there that you can purchase,
I (myself) have used "Glass Doctor" whenever one showed up on my windshield. They would come to the house and fix it there, while I sat inside sucking down coffee.
Don't believe your glass shop. If it's low on the windshield, I'd expect it to spread if you ever had to fire up the defroster on a cold winter morning. (Well.....as cold as it gets in Louisiana anyway
P
Old Jan 10, 2006 | 08:50 PM
BLKFLSH's Avatar
Default Re: Windshield star (P_Adams)
Well it's kind of the middle of the windshield as far as up and down and a little to the left of center of sight. I can't feel anything on the inside. I doubt they have a service like that around here. How much did it cost you? Did it make it invisible? If you didn't do it yourself, I sure don't want to try it, and maybe screw up my whole windshield over a tiny star. It doesn't sound too easy from the little I've read so far.
Old Jan 10, 2006 | 08:58 PM
hondadude's Avatar
don't wait for the glass to start cracking...call up the local windshield repair /replacement place The will probably use 'pit resin' to repair the nick and then the windshield won't start cracking. Cost probably around $35 ....much less than $150 for a new windshield. If at all possible have the car inside and the windshield over 70 degrees for the repair to work faster/easier.
Old Jan 10, 2006 | 09:07 PM
BLKFLSH's Avatar
Default Re: Windshield star (hondadude)
Have you ever done one with stuff I can buy at a parts store (advance)? Is it pretty easy if, like you say, it's over 70 degrees.
Old Jan 10, 2006 | 11:20 PM
Eddiebx's Avatar
defintely get any cracks fixed asap. i had a small crack on the bottom corner of my dad's camry, by the end of the week, it went straight across the window to the otehr end,
Old Jan 11, 2006 | 05:42 PM
vtec-adykt's Avatar
Default Re: (Eddiebx)
I actually repair windshields myself. Actually, my boss sent me to michigan to get trained. I have all the equipment to repair stars, bulls eyes, and other small imperfections. If you see a little bit of black in the damage, then it has a little bit of air in it. It needs to be sucked out, then resin must be injected into the damage via the pit ( small hole where the rock hit the glass) as long as the legs on the star haven't spread, your windshield can still be saved. In this case, a good repairman can literally make the damage disappear. All you should see is a clear flat bubble where the star once was. Bearly noticable. I would recommend you get another pro with more experience to look at it and fix it for you. It should range anywhere from 25-35 dollars.
Old Jan 11, 2006 | 05:51 PM
BLKFLSH's Avatar
Default Re: (vtec-adykt)
My insurance is going to cover it (with no cost to me) an appointment is going to be made tomorrow. I went to one glass shop and the guy told me that the hole was not all the way through the glass, and didn't need to be fixed. But all I do is stare at the damn thing the whole time I'm driving. I want it fixed.
Thanks too all who replied.
Old Jan 11, 2006 | 08:16 PM
P_Adams's Avatar
Default Re: (BLKFLSH)
Yeh, I love those cavalier attitudes. Quote
"Ah, don't worry about it: it's not going to get worst"
What they're REALLY saying is: "Ah, don't worry about it: It's not my car"
I know from ^%&$ experience how distracting those impact stars can be... always there, just within your field of vision; Grrrr
P
Old Jan 11, 2006 | 09:35 PM
Eddiebx's Avatar
Default Re: (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">Yeh, I love those cavalier attitudes. Quote
P</TD></TR></TABLE>
more like dont worry about it, till it spreads more and we can charge you to change the whole window
Old Jan 12, 2006 | 05:09 AM
amckee's Avatar
For the cheapos out there who are always looking for another way, If the star is not in your line of sight you can coat it in clear fingernail polish to keep it from spreading.
ttpjake
Paint and Body
Sep 24, 2013 08:13 PM
EJ8 GSR-T
Honda S2000
Nov 30, 2009 05:18 AM
daddy
Honda Civic (2001 - 2005)
12
Jul 7, 2007 09:54 AM
lukedogg49525
May 17, 2002 11:45 AM
masterxfob
Nov 9, 2001 04:00 PM
