Pitted windshield
Old Sep 15, 2013 | 05:38 AM
ttpjake's Avatar
Default Pitted windshield
This one is hard to explain. So let me try to do so the best that I can. My windshield looks like it's pitted. I tried windshield cleaning products and a glass scraper to try to remove the spots. No matter how hard I try, the spots are still there.
When I get glare from the low sun, I can't see **** out of my window because all I see are the spots.
When I gets humid and it rains at night and my windows fog up. The spots get worse and I can't get rid of them with heat/AC. Using wipers helps when they sweep past but make it worse when they come back down.
What can I do to fix this other than replacing the windshield? Is there a glass polishing compound? Any tricks to get rid of this problem? Or should I just spend close to $200 for a brand new windshield. This is really annoying.
Appreciate any input and help, thanks.
Old Sep 16, 2013 | 08:14 AM
mr500cm's Avatar
Default Re: Pitted windshield
Bring it to a glass shop and see if they can polish it out. Unless sand etched it, it should be able to be saved.
Old Sep 17, 2013 | 04:52 PM
Hidenplanvew's Avatar
Most times it more cost effective to replace the windshield. Its only around 130-150 for a window to be replaced.
Old Sep 18, 2013 | 04:06 PM
1998GsRIntegra's Avatar
Use a rotary buffer with a glass polishing pad and a glass polishing product that contains cerium oxide. That's the only way you'll remove any defects.
Old Sep 22, 2013 | 08:18 PM
Thats more for scratches then pit's... Once again its not exspensive to replace a windshield, also you can check for rust forming in that area.
Old Sep 24, 2013 | 05:19 PM
ttpjake's Avatar
The pitting is so annoying in the late afternoon sun. I can't find glass compound at the local AutoZone. I'm going to try car wax on a small section on the far upper right of the windshield. If it works, I'll do the rest. If it doesn't, I'll try a little harder in finding that glass compound. I may just get a new windshield eventually but it's not in the cards right now. I can get a windshield with the tint strip across the top in it already. Thanks everyone for your input.
Old Sep 24, 2013 | 08:13 PM
wax wont work.... Only thing is going to be replace
KAYTHAN
Sep 11, 2004 08:30 AM
joeseph
Mar 27, 2003 10:18 AM
chron1k2001
Nov 14, 2002 03:24 PM
IdotheSHOCKER
Jun 1, 2002 05:00 AM
lukedogg49525
May 17, 2002 11:45 AM
