turbo jdm h22!
if you tune it good the piston ringlands are the weak part of the motor i would put 8 psi to be safe or you can push it the ringlands i see alot go out at 300 whp 10 if tuned but i would put 8 psi
well, most people will tell you you shouldnt boost at all on a stock motor. and i mostly agree with that. on a stock jdm h22 i wouldnt go any higher than 6psi because the compression is so high.
from what i know..... 7psi is safe on mostly all honda motors, except the itr and ctr.
after 7psi, get hondata, or if your cheap, so uberdata
fmu's suck
fmu's suck
