car will not get into gear!!
Old Jan 9, 2006 | 03:40 PM
doggworld1233's Avatar
Default car will not get into gear!!
i have a 95 civic ex. with a d16z6 and a y8 head with z6 tranny. the car will not get into gear with the pedal on the floor but will go in with car off.
justin
Old Jan 9, 2006 | 03:41 PM
x93coupex's Avatar
Default Re: car will not get into gear!! (doggworld1233)
check you clutch fluid then make sure the tranny has fluid
Old Jan 9, 2006 | 03:52 PM
crohnman6's Avatar
Yea check yor fluid it happend to me and if it starts to happenin again every month or so then u you have a slave and probabely a master cylinder out pretty coomn in the egs
Default Re: car will not get into gear!! (x93coupex)
checked the clutch fluid it was a little low so i added and tranny should be fine it was checked like 3 months ago.
justin
Old Jan 10, 2006 | 08:33 AM
now car makes a noise when you press in the clutch peddal and some times gets stuck.
Old Jan 10, 2006 | 10:04 AM
ssbpturbohatch's Avatar
sounds like the throw out bearing is bad, anybody else agree???
Old Jan 10, 2006 | 10:23 AM
tsdenny's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doggworld1233 &raquo;</TD></TR><TR><TD CLASS="quote">now car makes a noise when you press in the clutch peddal and some times gets stuck.
what kind of noise?
squeeking noise is the spring
Old Jan 10, 2006 | 05:07 PM
Default Re: car will not get into gear!! (void_accord)
yep it is like a squeeking and there is oil around the clutch peddal. i think the slave pump or w.e. died. how can i change that? or is that the problem?
justin
Old Jan 10, 2006 | 06:14 PM
Tippyman's Avatar
Default Re: (crohnman6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crohnman6 &raquo;</TD></TR><TR><TD CLASS="quote">Yea check yor fluid it happend to me and if it starts to happenin again every month or so then u you have a slave and probabely a master cylinder out pretty coomn in the egs</TD></TR></TABLE> that get's my vote
Old Jan 11, 2006 | 07:08 PM
Default Re: (Tippyman98)
bump
Old Jan 11, 2006 | 07:15 PM
slow_redcivic's Avatar
Default Re: (doggworld1233)
i just had to fix mine. did you bleed your clutch when you added the new clutch fluid in? you might have air in there if it was low but if its the slave cylinder heres how to change it. its on the front of your tranny you dont have to jack the car up to take it off or change it. you'll see it to the left of your manifold. it comes out of a square rubber boot. There are 2 12mm bolts on the bottom of that take them out and using a 10 mm wrench loosen the nut that connects the line to the top of the slave cylinder. then take the slave cylinder outta the boot. check it and make sure there is a rod coming out. My problem was my springs on the inside was messed up might have to take it apart and check it all out. make sure to bleed the clutch when you get done, you might have air in there.
5speeder
Transmission & Drivetrain
Apr 28, 2012 09:38 AM
noob123
Aug 21, 2010 01:54 PM
dx_rex
Apr 20, 2007 03:22 PM
stingray2772
Mar 13, 2004 11:32 PM
Neptune
May 29, 2003 12:29 PM
