EFI SYSTEMS pms ecu, for turbo or boost application like greddy obd2
selling my piggy back ecu that i was running in my 98 ITR. its a efi systems programmable management system. system works similar to a greddy e-manage. includes everything needed to plug and play into your car and have it running. it has a direct usb link with cord to plug ecu right into laptop for full tuning capabilities. heres a bit off their website on what this computer is capable of:
The Programmable Management System from EFI Systems is a state-of-the-art microprocessor-controlled engine control system . The PMS reads the stock fuel injection and spark timing signals from the engine's control unit, then changes them to the settings that you specify via terminal or PC laptop entry. This allows different fuel and timing adjustments in 500 RPM increments to be made for the following engine states:
Idle
Part Throttle
Wide Open Throttle
Boost
Nitrous
Air Temp
Engine Temp
more info can be found on EFI SYSTEMS website:
http://efisystems.com/pms.html
asking price is $450 obo retail on their site is $899.99
the harness that it has on it, is direct plug in between an obd2a ecu and wiring harness. meaning direct plug and play for any 96-98 civic or 96-98 integra. can be used in anyother honda/acura application, just wire it into your harness.
i ran this setup in my ITR for a few years, it was last tuned to 11psi of boost on a stock block ITR. it also has hook up for 3 bar map sensor or u can run your stock one. lots of tuning capabilities, make your boosted honda run like factory. pm me with offers
Modified by c5_el at 5:36 PM 1/9/2006
Idle
Part Throttle
Wide Open Throttle
Boost
Nitrous
Air Temp
Engine Temp
VTECPWR
Jul 30, 2005 09:59 AM
Boosthead
Sep 30, 2003 06:46 AM
