EFI Systems programable management system
Old Aug 16, 2003 | 02:15 PM
Boosthead's Avatar
Default EFI Systems programable management system
EFI Systems PMS with OBD2 harness and 3 bar map sensor
$450
Old Aug 17, 2003 | 06:44 PM
Boosthead's Avatar
Default Re: EFI Systems programable management system (Boosthead)
Old Aug 18, 2003 | 03:40 PM
xenocron's Avatar
Does it come with the InterAq software?
Old Aug 18, 2003 | 06:28 PM
Boosthead's Avatar
Default Re: EFI Systems programable management system (xenocron)
No
Old Aug 22, 2003 | 06:30 PM
Boosthead's Avatar
ttt
Old Aug 25, 2003 | 06:07 AM
Boosthead's Avatar
last bump
The Programmable Management System from EFI Systems is a state-of-the-art microprocessor-controlled engine control system . The PMS reads the stock fuel injection and spark timing signals from the engine's control unit, then changes them to the settings that you specify via terminal or PC laptop entry. This allows different fuel and timing adjustments to be made for the following engine states:
Idle
Part Throttle
Wide Open Throttle.
The PMS includes specialized functions for maximizing the performance of turbocharged, supercharged, and nitrous-oxide fuel-injected engines, including turbo boost control, for engines that are equipped for it. There are also two user-programmable switches that allow the PMS to activate power adders like nitrous oxide, with two stages that need to be activated at different times. The non-volatile storage area of the PMS allows you to create and store three different performance programs for different operating conditions; For example, you may define one program for the everyday street use, one for the track, and one for maximum highway performance. The PMS even gives you the ability to change individual settings or programs instantly, even while driving.
The PMS can monitor your stock engine control unit and give you the ability to control the engine's timing and fuel curves. It controls the timing in one-degree increments and the fuel in two-percent increments.
The PMS makes the use of aftermarket performance "chips" obsolete. All aftermarket chips are a compromise between performance and everyday driving, as the chip maker cannot burn a dedicated chip for a car without having input from that car's engine control system. As you may see from looking at cars at the local drag strip or street, not all cars of the same type having the same setup (i.e. stock or modified) have the same performance. The other problem that you face with "chips" is that they cannot be re-programmed for changing conditions or different engine modifications. The PMS gives you the flexibility to modify and maximize your engine's performance with just a change to the data - at any time - whether driving or just sitting in your car.
Old Sep 28, 2003 | 10:19 AM
Boosthead's Avatar
$450 plus shipping
Old Sep 30, 2003 | 06:46 AM
Boosthead's Avatar
ttt
c5_el
Jan 11, 2006 03:43 PM
VTECPWR
Jul 30, 2005 09:59 AM
Team 4
Feb 11, 2005 07:11 AM
Boosthead
Aug 25, 2003 06:06 AM
