JDM Climate Control Help
Old Jan 9, 2006 | 11:29 AM
Silver Surfer's Avatar
Default JDM Climate Control Help
So i am already done installing that is not the problem.....looks great i love it.
However, when i turn the ac on my ac compressor does not come on
and i assume there is supposed to be back lighting for the buttons at night....when i turn my lights on at night the only thing lit is the display.
Can anyone help me diagnose?
oh yeah and when i plugged up my srs the light never when off....have a bad feeling about that one. But they are both plugged in.
Old Jan 9, 2006 | 08:16 PM
Default Re: JDM Climate Control Help (Silver Surfer)
bttt
Old Jan 9, 2006 | 10:03 PM
onefastrx7turbo's Avatar
i'd start with fuses and relays, esp. since you said some of the buttons arent lighting up either....
Old Jan 10, 2006 | 01:18 AM
snowblind7x's Avatar
which buttons don't light? the "fan/mode/ac" ones? If you mean those....mine don't light up either, i dunno if they're supposed to. It looks like they probably should but i dunno...
Old Jan 10, 2006 | 06:11 AM
yeah the display lights up fine, everything works there. I just assumed the words under the buttons should light up at night.
I guess my main concern is the srs light right now cause i gotta get my car inspected this month.
The ac compressor can wait a few months if necessary
Old Jan 10, 2006 | 09:07 AM
elnoyl's Avatar
Default Re: (Silver Surfer)
i had the same problem. I used forbiddens writeup and it didn't mention the a/c wire in it. I'm assuming that's the problem so get the wiring diagram for the jdm climate control and find out what color the a/c wire is on the u.s. unit and connect them together and that should fix that problem. For the srs you need to do a reset assuming all of your srs components are in perfect working order. That can be done by jumping the plug next to the cel one in a certain order. Search for that someone will have the needed sequence to reset that.
Old Jan 10, 2006 | 09:09 AM
elnoyl's Avatar
all of the lights are suppose to light up at night even the blue and red for the temp selector.
Old Jan 10, 2006 | 11:22 AM
Default Re: (elnoyl)
my blue and red for the temp selector light up but those 3 buttons on the left dont light up. You sure they're supposed to? anyone ahve any pics with those buttons lit up...?
Old Jan 10, 2006 | 05:44 PM
all i found in my srs search was something for a hatch.....i looked a helms and it suggested that i might have a bad ground.....but i would like to try to reset first before i go wire searching. Anyone know how to do this?
Old Jan 10, 2006 | 06:41 PM
elnoyl's Avatar
yes all buttons are suppose to light up. I said all including the red and blue. I have a 100% functional one installed in my car.
Old Jan 10, 2006 | 07:04 PM
Siegfried's Avatar
Check this thread
https://honda-tech.com/zero...age=1
Maybe you forgot to wire the #1 blu/yel wire to the JDM pin 20.
Old Jan 10, 2006 | 08:42 PM
i got the #1 blu/yel wire to the JDM pin 20 connected to the #1 blu/red on USDM. I was looking at the diagram posted and it says they #1 blu/red on usdm is ac thermostat and the #2 green is the ac switch. Why is the green wire not connected to anything on the JDM?
I guess I am gonna take my long mlk weekend to source these problems
Old Jan 10, 2006 | 10:27 PM
Siegfried's Avatar
I don' t remember what color the wire is and to wich connector it goes but check the diagram on jrcormier.
I had the same problem, my compressor wasn't running too, it was because of the missing wire (my climate control was turning on even the A/C wasn't working).
If yours is already connected then maybe the problem comes from the A/C relay located on the front driver side or from the switch on the condenser.
Hondatypr636
17
Jun 26, 2014 09:24 AM
M2B4
Aug 18, 2007 04:41 PM
snowblind7x
Jul 3, 2006 11:20 PM
BoBoChan
Aug 27, 2005 11:31 AM
