DIY - AVCR or VAFC Mounting to Rear View Mirror revisited
Old Jan 9, 2006 | 11:01 AM
JokerX-1.6T's Avatar
Default DIY - AVCR or VAFC , SAFC Mounting to Rear View Mirror revisited
This is a DIY that I came across a long time ago here on HT https://honda-tech.com/zerothread?id=552288 - I just finally got bored enough to try it today in my Civic - as the original post was in a Teg -
Some people like to keep there Vafc or Avcr hidden since I use my avcr for my boost gauge as well as other functions I want it out in the open but not super visible to everyone and thanx to <U>dLo homey-GS-RaRrRrR!</U> in the above thread from 2003 - I figured time to give it a shot after like a year or so of saying I was gonna try that someday
Parts Used :
As stated in original post I used 6 32 x 1/2 but Instead of rounded head I used flat head as It seemed to give plenty more clearance with no problems what so ever
some # 6 lock washers its up to you
30ft 22gauge wire any color (just make sure you connect the correct wires to each other) - Radioshack
A soldering gun and some solder
Electrical Tape
Some Patience
Some Scotch or 3M Heavy Duty Double Sided Tape - Home Depot - Lowes doesnt have it
Drill and a bit to drill the holes for your 6/32 x 1/2" holes
So anyway here it is
I lined up the mount where I wanted it than marked the spots to be drilled with a sharpie - - no pics but pretty self explainable
Popped off the plastic piece from the mirror whith a flathead screwdriver - self explainable again
Drilled out the 2 holes and than procided to put the Avcr mount to the piece with the 6/32 x 1/2" flathead type screws with bolts and lockwashers and I got this - I also cuth the mount feet down to about the aidth of the mirror piece - which can really restrict the visors if you dont
Than on the other side i drilled 1 hole in the middle which I didnt get a shot of but it
was directly in the middle right about where the arrow is pointing to
So after that was done it a test fit time to see how it would mount back into position
Here you can see kinds blurry that I used velcro here ( I actually found the velcro did not hold like i wanted it to so went with some scotch heavy duty double sided tape)
Now to get the avcr all the way up top I had to lengthen the wires in the harness so if you dont like cutting and soldering than your done or find someone who you trust to do it
One last wire to tape up
And heres what I ended up with when done
( I used 10 - 3ft pieces of 22gauge wire to extend)
Now plug the harness back together and make sure it works
After alittle electrical tape heres what ya get
Now after you remove the pillar piece (be careful it can be a pain in the a**)
and plastic piece on the far right hand side of the dash (sorry no pics)
you can run the wire up the side than into the pillar - leave enough so you can pull the wire behind and wire tie it to the mirror
Now after you have put all the pieces back together (A the pillar first - B than the side piece you should have a avcr or a vafc hanging from the cieling of your car
Now tighten the mount on the rear view mirror - than position the Avcr or Vafc where you want it - remember the double stick tape doesnt have much give so get it where you want it the first time if possible
I than wire tied and tucked the extra wire into the little gap between the windshield and the headliner
Now sit back and realize just how good it looks
1 sidenote - I keep my sunvisors pushed all the way against my windshield so Due to the width of the Avcr or Vafc I can only pull the visors back about 3/4's of the way than I have to fold the Avcr down on the hinge to allow them to go fully back into position against the headliner - so if you keep yours in the stock position just keep in mind everytime you want them down there may be some moving on the Unit
Modified by JoKeRX at 4:52 PM 1/9/2006
Old Jan 9, 2006 | 11:03 AM
dohcVTECeg2's Avatar
Default Re: DIY - AVCR or VAFC Mounting to Rear View Mirror revisited (JoKeRX)
looks good
Old Jan 9, 2006 | 11:09 AM
Luserkid's Avatar
Default Re: DIY - AVCR or VAFC Mounting to Rear View Mirror revisited (dohcVTECeg2)
damn thats really clean
Old Jan 9, 2006 | 11:10 AM
acidburn2k2's Avatar
damn man, that looks nice n clean, good install
Old Jan 9, 2006 | 03:14 PM
thanx -
Old Jan 9, 2006 | 03:50 PM
moores55's Avatar
Default Re: (JoKeRX)
yea looks good not only to us but to thiefs.
Old Jan 9, 2006 | 04:00 PM
CivicSiRX's Avatar
i love it when i see vafc installs. i install mines in the same spot a year ago. looks good and is out of the way.
Old Jan 9, 2006 | 04:09 PM
97spooncivic's Avatar
Default Re: (CivicSiRX)
looks really clean. nice
Old Jan 9, 2006 | 04:59 PM
urnotfast's Avatar
Default Re: DIY - AVCR or VAFC , SAFC Mounting to Rear View Mirror revisited (JoKeRX)
super clean install
gotta love diy
Old Jan 9, 2006 | 05:41 PM
VTAC-KAT's Avatar
stealthy
Old Jan 9, 2006 | 05:47 PM
Noeladams's Avatar
Default Re: DIY - AVCR or VAFC , SAFC Mounting to Rear View Mirror revisited (auctionaccess)
I like it........... Great DIY
Old Jan 12, 2006 | 10:26 AM
Default Re: DIY - AVCR or VAFC , SAFC Mounting to Rear View Mirror revisited (Noeladams)
Yea it actually works out in that spot really well - more than I thought it would to tell the truth
Old Jan 12, 2006 | 10:49 AM
mwieczorek43's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moores55 &raquo;</TD></TR><TR><TD CLASS="quote">yea looks good not only to us but to thiefs.</TD></TR></TABLE>
I actually think it might be out of the line out sight from the window.
How visible is it from the outside?
Old Jan 12, 2006 | 10:55 AM
-Gambit-'s Avatar
Default Re: DIY - AVCR or VAFC Mounting to Rear View Mirror revisited (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">damn thats really clean </TD></TR></TABLE>
Old Jan 12, 2006 | 02:04 PM
EM199dcs's Avatar
Hey, thats clean man. its mounted better then the orginal post you were look at. When i seen the pics of you lengthning the wires i was a little worried to see how it came out. but thats clean bro. nice work.
Old Jan 12, 2006 | 02:53 PM
senpai's Avatar
that's cool, no doubt but I like to see the pretty numbers when I drive - yep, ricer like that
Old Jan 12, 2006 | 03:32 PM
Laserjock's Avatar
Default Re: DIY - AVCR or VAFC , SAFC Mounting to Rear View Mirror revisited (senpai)
A well done How-to!
uh, can I come over and use your garage?
Old Jan 19, 2006 | 11:19 AM
Default Re: DIY - AVCR or VAFC , SAFC Mounting to Rear View Mirror revisited (Laserjock)
If your serious than yea if you need some space to work on something lemme know if your not serious well
Old Jan 19, 2006 | 11:23 AM
litterbox's Avatar
I am a (Trial User) Army
Clean!
Old Jan 19, 2006 | 11:33 AM
dohcMONSTER's Avatar
Default Re: DIY - AVCR or VAFC , SAFC Mounting to Rear View Mirror revisited (litterbox)
Old Jan 19, 2006 | 04:04 PM
JustG's Avatar
Default Re: DIY - AVCR or VAFC , SAFC Mounting to Rear View Mirror revisited (dohcMONSTER)
Very nice!! i guess if you wanted to hide it a lil more you could use an 8" bar of window tint across the top of the windshield. Great job tho'!!
Old Jan 19, 2006 | 04:31 PM
Default Re: DIY - AVCR or VAFC , SAFC Mounting to Rear View Mirror revisited (JustG)
actually from the outside you really cant see anthing that would make you want to look closer
Old Jan 19, 2006 | 04:55 PM
ekay. jay's Avatar
very clean
Old Jan 19, 2006 | 05:52 PM
EK2.0's Avatar
Very clean!!
Old Jan 19, 2006 | 06:00 PM
BlueIntegraBoy's Avatar
very clean install
