Firewall Fuel hardline nut fitting size??
Old Jan 9, 2006 | 08:13 AM
Chase's Avatar
Default Firewall Fuel hardline nut fitting size??
I need to know the thread pattern on this nut here. (found this pic in another thread that didnt help much)
Reason why is i got all the stuff to run stainless lines from the hardline. (Tube sleeve, tube nut, hoses, earls inline fuel filter, etc)
But where the hardline comes out from the firewall i dont think its long enough b4 it bends in through the firewall to get my tube cutter to cut it, then put on the tube sleeve and nut, and then flare it.
So basically i need to know cuz i found some cool Fuel Injection adapters on http://www.anplumbing.com but they only come in 14 x 1.5mm and 16MM x 1.5.
Also if anyone has done something else, found another alternative, or has input feel free to share. TIA!!
Old Jan 9, 2006 | 08:17 AM
Jonathan_ED3's Avatar
Find some lose Honda nuts and start trying to screw them on.
When one fits, take it to Home Depot, Lowes etc and test the thread pitch on one of those gauges.
Or get the tool that will allow you to figure out the pitch without the use of a testing a nut.
You can usually find them in the tap and die section of tool places.
Old Jan 9, 2006 | 08:32 AM
Chase's Avatar
Default Re: (Jonathan_ED3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 &raquo;</TD></TR><TR><TD CLASS="quote">Find some lose Honda nuts and start trying to screw them on.
You can usually find them in the tap and die section of tool places. </TD></TR></TABLE>
Thanks for the suggestion. but i drive my car everywhere so i dont wanna do that, plus im sure someone here will know...
Old Jan 9, 2006 | 08:50 AM
What do you mean you drive your car everywhere?
What does that have to do with anything.
Every Honda enthusiast should have a box of loose "Honda" nuts and bolts!
They come in very handy for situations like this
Old Jan 9, 2006 | 08:59 AM
Chase's Avatar
haha i mean...im at work now, and i drove my car here. i would hafta undo all my fuel lines to try to thread a buncha bolts on there. When i could just sit here on my work computer and see if people know hahaha
Old Jan 9, 2006 | 09:07 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (EF8kid)
I came up with 14mm X 1.5mm pitch..
Somewhere there are a couple of threads on this..
look around..
Try here:
https://honda-tech.com/zerothread?id=1452210
The information was already provided in a thread You participated in..
How about that...
Old Jan 9, 2006 | 09:15 AM
Chase's Avatar
Default Re: (88DXCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">I came up with 14mm X 1.5mm pitch..
look around..
Try here:
How about that...
well thats a EK...i didnt know if EF was different.
So you u measured the threads on EF's and it was 14mm x 1.5 ???
If thats correct then thats AWESOME!! Makes things easier, THANKS
Old Jan 9, 2006 | 09:26 AM
88DXCRX's Avatar
1988 CRX HF:
14mm X 1.5mm.
Old Jan 9, 2006 | 09:40 AM
Chase's Avatar
88DXCRX IS THE MAN!!!!
THANKS!!!!!!! This made my day yayyy
alfaaay
Jul 28, 2005 12:48 PM
NVMYSi
Dec 15, 2004 01:05 PM
JDMorgan
Jul 24, 2004 11:58 AM
Lyrikz
Sep 17, 2003 07:27 AM
D0HC
Dec 19, 2002 01:23 PM
