Code 14 what does that consists of ?
Old Jan 9, 2006 | 05:14 AM
Jdmb18EF's Avatar
Default Code 14 what does that consists of ?
Hey people wats up i jus got a check engine light and i read the red light and its code 14 wat should i check for that.
Old Jan 9, 2006 | 07:20 PM
jdmcars.com's Avatar
Default Re: Code 14 what does that consists of ? (Jdmb18EF)
People are going to tell you to "search" but since you are new, I'll help.
Code 14 =IAC Valve (Idle Air Control)
Check to see if unplugged. Uncommon sensor to go bad, so if not unplug, I would then look for bad/broken wiring.
Depending on your engine/car, but most cars the IAC is located on the back side of the intake manifold.
Old Jan 17, 2006 | 05:34 AM
Jdmb18EF's Avatar
Default Re: Code 14 what does that consists of ? (jdmcars.com)
thankx
skaternak
Oct 29, 2008 01:40 PM
team 15
Apr 21, 2008 05:49 PM
1998_4dr_gsr
Oct 27, 2006 03:21 PM
IgniteTeg
Aug 8, 2002 09:26 AM
IgniteTeg
Aug 7, 2002 06:54 PM
