Tech Ques: D16Z6 or D16Y8 Vtec head in 98 hatch?
Old Jan 8, 2006 | 09:38 PM
powerslide360's Avatar
Default Tech Ques: D16Z6 or D16Y8 Vtec head in 98 hatch?
Which would be an easier swap into a 98 EK Hatch -- a Z6 or Y8 head? How would I go about wiring the head up since the car is OBDII and a Z6 head is OBDI?
Old Jan 8, 2006 | 09:40 PM
EK k kay's Avatar
Default Re: Tech Ques: D16Z6 or D16Y8 Vtec head in 98 hatch? (powerslide360)
y8 is easier if you are going to put it on the stock y7 block.
Old Jan 8, 2006 | 09:41 PM
Default Re: Tech Ques: D16Z6 or D16Y8 Vtec head in 98 hatch? (EK k kay)
Going to pretty much build a Mini Me for now -- should I just get the wiring harness from an EX and swap it all up? it would be easier to hook everything up without splicing the harness right?
Old Jan 8, 2006 | 09:45 PM
EK k kay's Avatar
If you want to do that you can, but I just used my stock y7 harness. All I had to do was re-wire two of the IACV wires and run 4 tires from the IACV, knock sensor, vtec oil pressure, and vtec solenoid to the ecu.
Jdmhondaowner
May 29, 2014 09:40 PM
SpdKilz23
10
Apr 11, 2009 02:48 PM
Cras-Delsol
15
Sep 19, 2008 09:39 PM
tobe1424
Feb 20, 2006 06:16 PM
ss20gsr
Feb 24, 2004 04:17 PM
