buzzing noise
Old Jan 8, 2006 | 06:24 PM
wingback44's Avatar
Default buzzing noise
my 1994 LX has started making a buzzing noise under the front passenger and driver seats. i am going to get it up in the air tomorrow but i was wondering what i should be looking for. it sounds like it might be metal rubbing on metal and i was wondering what, if any, areas i should be looking in.
Old Jan 8, 2006 | 06:47 PM
Ross 2.0's Avatar
In a Junkyard near you.
Probably a loose cat heat shield. Either way it's probably an exhaust shield.
Old Jan 8, 2006 | 07:02 PM
wingback44's Avatar
Default Re: (MooGoCow3)
thats what i thought but i wasnt sure
ill tighten that up tomorrow
Old Jan 8, 2006 | 07:21 PM
hondadude's Avatar
Default Re: buzzing noise (wingback44)
The first spring loaded joint behind the oil pan is known to cause an 1800rpm buzz. honda put out an upgrade kit with stiffer springs, you might try adding a few washers under the springs to see if it changes.
Old Jan 8, 2006 | 07:22 PM
P_Adams's Avatar
If it occures around 2000rpm, it's most likely the Catalytic Converter's Upper Heat Shield. (the welds break)
I suggest linking together several stainless steel worm style hose clamps, wrap at least two of these around the converter and tighten within an inch of it's life
P
Old Jan 9, 2006 | 01:29 PM
wingback44's Avatar
Default Re: buzzing noise (P_Adams)
it was the heat sheild on the underside of the catalytic converter. i have to run out and get some worm style hose clamps to keep it from buzzing. thanks for the help you guys.
Old Jan 9, 2006 | 02:27 PM
P_Adams's Avatar
Another Successful repair by a Honda-Tech advised Honda Owner!!!
Glad WE ALL could help; and thanks for the "That Fixed It" Report
P
Old Jan 9, 2006 | 02:32 PM
Honda-Master's Avatar
if shield is ok,, you might need the mid pipe kit.............kit # 18010-SV4-305...get it from honda dealer
Old Jan 9, 2006 | 02:33 PM
ooooooops sorry did not read that it was fixed already..
elly7b
Feb 6, 2014 04:54 PM
05rsxS
Sep 15, 2008 03:36 PM
Smeeg Heed
Dec 19, 2004 05:34 AM
DC2_Integra
Mar 26, 2003 04:29 PM
E Swift
Sep 10, 2001 11:05 AM
