anyone bosot a d-16 i have some fuel questions
Old Jan 8, 2006 | 04:43 PM
386kustoms's Avatar
Default anyone bosot a d-16 i have some fuel questions
i have a 96 d-16 i just put a t-25 in i orderd a 6 psi wastegate that i will be putting in there and i have a boost controler that i will set at 8 psi for when i need it. i am not gona race this car and i dont want to go all out on it just something fun to drive. i have nto done anything w the fuel system yet i dont think i need to do everythign that i was told i have to like fuel pressure regulator, bigger injectors, pump, s-afc. can i get away a little cheaper by just installing a rising rate regulator like a 12:1 i just want the motor to be safe and not blow on me any imput will help thanx jason
Old Jan 8, 2006 | 05:38 PM
zeroice's Avatar
Default Re: anyone bosot a d-16 i have some fuel questions (386kustoms)
you can use an fmu, not really safe per safe compared to tuning the car but it will work without bigger injectors and feul pump.
Old Jan 8, 2006 | 05:47 PM
coneheadsracing's Avatar
Default Re: anyone bosot a d-16 i have some fuel questions (zeroice)
i don't know how much fmu's run, but whatever you choose i'd get something that will retard your timing based on the boost, personaly. I watched my friend take out ring lands on two seperate occasions. By that point, a conversion harness and a chipped ecu, would be lots cheaper. If you already have a laptop, i'd go that way, especialy if you know someone with a wideband.
Old Jan 8, 2006 | 06:23 PM
386kustoms's Avatar
i am really new to all of this i mostly play w older carburated n/a cars from teh 60's what type of fmu should i get like a 12:1 or what exactly i hate soundidn stupid but i just want to know as much as i can
89efDUSTY
Dec 26, 2006 11:42 AM
VTECth1s
Apr 22, 2006 09:42 AM
90crxsi88zc
Oct 6, 2005 03:18 PM
2k1civicturbo
Jan 23, 2003 10:43 AM
pelotudo
Sep 14, 2002 12:35 PM
