Installed Neg. Battery terminal & new ground
Old Jan 8, 2006 | 01:26 PM
josephshark's Avatar
Default Installed Neg. Battery terminal & new ground
I installed my new neg. battery terminal, and new wire, also I replaced one of the stock grounds.
I am guessing that the ecu reset after having the neg. ter. off of the battery for more than 10 minutes.
When I initially started the car, the idle was going up and down, after about 30-1 minute it stopped and leveled off. I had to use some pb blaster to losen the screws, could this have caused the idle to hunt?
What is the ground wire connected to in this picture besides the radiator support ?
Prior to doing this work, the cruise control had a lag of maybe 20 seconds before it engaged, after doing this work, the cruise engages immediately???
This is the setup on the battery
Old Jan 8, 2006 | 01:43 PM
.Kevin.'s Avatar
Default Re: Installed Neg. Battery terminal & new ground (josephshark)
my car idles like that when if first starts up all the time, i belive its just a normal thing for it to do. And the pb blaster would not have done that but just clean all the connecting terminals off and dont leave them wet with pb blaster
Old Jan 8, 2006 | 02:08 PM
Default Re: Installed Neg. Battery terminal & new ground (Slow_CvC99)
I cleaned the area for any remaining pb blaster.
My car did not hunt for idle like this before, either way it went away after a less than a minute. This the sort thing that makes me all the more paranoid
Old Jan 8, 2006 | 02:09 PM
VTECisSeXY's Avatar
*insert here*
your ecu got reset... no biggie
Old Jan 8, 2006 | 03:48 PM
old man neri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by josephshark &raquo;</TD></TR><TR><TD CLASS="quote">I cleaned the area for any remaining pb blaster.
My car did not hunt for idle like this before, either way it went away after a less than a minute. This the sort thing that makes me all the more paranoid </TD></TR></TABLE>
is it still doing it now? If it isn't I really wouldn't worry about it.
Old Jan 8, 2006 | 04:06 PM
Default Re: Installed Neg. Battery terminal & new ground (old man neri)
Thanks guys,
It did not happen on the second or third start.
Can you tell me what the thing connected to the ground wire connected to the radiator support is ?
Old Jan 8, 2006 | 04:10 PM
RedEj8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by josephshark &raquo;</TD></TR><TR><TD CLASS="quote">Can you tell me what the thing connected to the ground wire connected to the radiator support is ?
Umm the power steering pump bracket? Is that what ur talking about?
Old Jan 8, 2006 | 05:51 PM
Default Re: Installed Neg. Battery terminal & new ground (reddohcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reddohcvtec &raquo;</TD></TR><TR><TD CLASS="quote">
Umm the power steering pump bracket? Is that what ur talking about?</TD></TR></TABLE>
lol, I don't know, that's why I'm asking.
Old Jan 14, 2006 | 09:07 AM
RedEj8's Avatar
Haha well yea thats what the ground wire goes to
Old Jan 14, 2006 | 12:16 PM
JeffBro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_CvC99 &raquo;</TD></TR><TR><TD CLASS="quote">my car idles like that when if first starts up all the time, i belive its just a normal thing for it to do. And the pb blaster would not have done that but just clean all the connecting terminals off and dont leave them wet with pb blaster</TD></TR></TABLE>
Something is wrong with your car.
josephshark
Your ecu just reset no big deal. Pre obd 1 cars will recalibrate the idle after the ecu resets its normal.
Old Jan 14, 2006 | 02:15 PM
Default Re: (XhaloZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XhaloZ &raquo;</TD></TR><TR><TD CLASS="quote">Yeah the ECU reset, it idles up and down because the ECU is trying to see how much air is enough air for the motor to idle. Like when you add a new intake, it does the same thing because you are making it easier to put air into the motor and the air is a different temperature depending on which intake you get. Oh and where did you get those blue cables?</TD></TR></TABLE>
The cables are stinger power wires hpm , I purchased them on ebay.
Old Apr 5, 2009 | 06:36 AM
driveslow's Avatar
Back from the motherf*****dead kids.
If you look at the first pic, my radiator support ground to power steering bracket is the same as his. I was looking at my manual and it has this ground going from the radiator support then to THE VALVE COVER. which way is correct or normal or better?
D Griff
14
Nov 13, 2009 01:26 PM
I Like Hondas
20
Oct 18, 2006 01:54 PM
PINKS
27
Jun 5, 2006 05:57 PM
PINKS
13
Jun 4, 2006 09:11 AM
crxh22project
Mar 14, 2005 04:52 PM
