difference between d16 and d15?
Old Jan 8, 2006 | 10:06 AM
crxhf19's Avatar
Default difference between d16 and d15?
what is the difference between these two, are the rods the same and it is just the bore? if so then can i bore out a d15 block to make d16 pistons fit? thanks adam
Old Jan 8, 2006 | 10:40 AM
crxhf19's Avatar
Default Re: difference between d16 and d15? (crxhf19)
bump for some help before i waste my money on rods that wont fit
Old Jan 8, 2006 | 10:50 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
D15 connecting rod large end bore diameter=45.0mm
D16 connecting rod large end bore diameter=48.0mm
The crankshafts have different size journals so no...
And a D16 crank won't fit in a D15 block either because
the main journals are different sizes..
Old Jan 8, 2006 | 11:47 AM
jlicrx's Avatar
Default Re: difference between d16 and d15? (88DXCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">D15 connecting rod large end bore diameter=45.0mm
true for DX
HF is 41.0mm
Old Jan 8, 2006 | 12:00 PM
88DXCRX's Avatar
Default Re: difference between d16 and d15? (jlicrx)
Right..
I saw that in the manual but did not post it..
Either way,It is probably not happening..
civicxxman
Feb 10, 2008 10:48 AM
opelorc
Sep 12, 2007 10:46 AM
yusoslo
Dec 16, 2003 06:56 PM
CRwreckz
Feb 19, 2003 07:21 AM
CovertFI
Aug 1, 2002 08:59 PM
