Antenna mast is not retracting....
This problem just occured to me in the past couple of days. The antenna mast always stays up whether if the radio is on or not and I cant get the mast to go back down. I think the motor is still fine. I can still hear it running. Is there a certain part I can buy from the dealership or do I have to buy the whole replacement set?
You probably need to replace the 'antenna mast' This link should help you
http://members.troublecodes.ne...a.htm
Webpage was made by a really nice guy
From what I have read, the gear gets stipped on one side. you can take it apart, flip the gear over and lube it up and use it some more.
SleepinGSR
Feb 27, 2002 02:03 PM
