The BLITZ® DTT (Dual Turbo Timer) DCll ?/
Old Jan 7, 2006 | 07:09 PM
EJ8 GSR-T's Avatar
Default The BLITZ® DTT (Dual Turbo Timer) DCll ?/
Hey i have a ? how does the DTT read boost? In my turbo d series this probably wont work right? its not a manual reader it would only know boost from the ECU right?
Old Jan 7, 2006 | 07:30 PM
po_snake's Avatar
The timer reads boost from it own vacuum line.
Old Jan 7, 2006 | 10:04 PM
EJ8 GSR-T's Avatar
Default Re: (po_snake)
so it actually would work as on my car? is it accurate? as in could i use it instad of a boost gauge?
Old Jan 8, 2006 | 07:04 AM
EJ8 GSR-T's Avatar
Default Re: (userdead626)
damn 42 reads and no more info?
Modified by userdead626 at 11:02 AM 1/8/2006
Old Jan 8, 2006 | 04:31 PM
EJ8 GSR-T's Avatar
Default Re: The BLITZ® DTT (Dual Turbo Timer) DCll ?/ (userdead626)
bump
Old Jan 8, 2006 | 05:04 PM
orion840's Avatar
Default Re: The BLITZ® DTT (userdead626)
yea i would like to know to cuz i am gonna do the same thing. man u read my mind i was just about to make this post.
come on lets get some info
Old Jan 8, 2006 | 05:12 PM
Dartanian's Avatar
My buddy has one. Yes, it is accurate and yes, you can use it instead of a boost gauge. I don't remember if it reads in kPa or psi, though.
Old Jan 8, 2006 | 06:01 PM
orion840's Avatar
Default Re: (Das Schmoo)
cool thanx for the info
Old Jan 9, 2006 | 06:22 PM
po_snake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Schmoo &raquo;</TD></TR><TR><TD CLASS="quote">My buddy has one. Yes, it is accurate and yes, you can use it instead of a boost gauge. I don't remember if it reads in kPa or psi, though.</TD></TR></TABLE>I use mine as a boost gauge, it reads in kpa so you have to do the conversion. It will also log peak boost and you can set a warning alarm for the max boost you want to run.
turbohatch96y7
May 24, 2009 10:58 PM
nicktagz
Aug 28, 2006 07:56 PM
EJ8 GSR-T
Jan 8, 2006 04:29 PM
grnsol
Feb 22, 2002 06:35 PM
DIRep972
Nov 16, 2001 03:22 PM
