What plug gap should I use for 12:1 compression and which plugs?
Old Mar 19, 2002 | 11:04 PM
jonnybravo's Avatar
Default What plug gap should I use for 12:1 compression and which plugs?
I was maybe looking towards the Bosh Platinum 4 because of the dyno sheet found here-> http://www.importreview.com/reviews/densoVSbosch.html . So which ones do you guys think or know from experience to be the best and what gap should I use for the high compression?
Old Mar 20, 2002 | 12:08 AM
Vtec integra's Avatar
Default Re: What plug gap should I use for 12:1 compression and which plugs? (jonnybravo)
denso's are alright. with 12:1 i sugguest the ngk 7e's. i have went through two sets os denso iridiums in the last 6 months. i hear bad stuff about bosch's on the long run.
Old Mar 20, 2002 | 10:30 AM
jonnybravo's Avatar
Default Re: What plug gap should I use for 12:1 compression and which plugs? (Vtec integra)
anyone else?? Please I need opinions.
Old Mar 20, 2002 | 10:34 AM
ENDYN's Avatar
The Old One
My new engine came with Bosch F6-DP plugs in it. They are not the +4 design. The part number is 4227 and my build sheet says to gap them at .035".
Old Mar 20, 2002 | 10:49 AM
mingchi96
Guest
Posts: n/a
spark plug gap shouldnt really have anything to do with the compression. It is more dependant on wat ignition you use. If you use stock ignition, then gap any sparkplugs you use to stock specs.. which is roughly .035" If you have msd and an external coil, gap them @ .045" since the spark is stronger. WI have the bosch F6DP on my fully built b20/vtec gapped @ .045" with an msd and absolutely no prob.
Old Mar 20, 2002 | 10:52 AM
Casey's Avatar
Default Re: What plug gap should I use for 12:1 compression and which plugs? (mingchi96)
what about 12.5:1? same plugs? thanks for helping either of us
Old Mar 20, 2002 | 10:56 AM
Big Phat R's Avatar
I was using the Spoon "Racing Plugs" (denso iridiums) one temp range colder. The engine didn't run very well when cold and I have since switched back to stock (much better). I will probably use the Spoon plugs at the track though.
Old Mar 20, 2002 | 11:01 AM
Mike K's Avatar
Default Re: What plug gap should I use for 12:1 compression and which plugs? (BPR)
Use PFR6G-11.
Gap them at 1.1mm, as the '11' in the part number suggests.
Old Mar 20, 2002 | 11:03 AM
Casey's Avatar
should an engine that is modified stick with stock plugs?? I have 12.5 compression, ctr cams, mugen header, tanabe exaust, intake, vafc and mugen ecu
VTEC4GS's Avatar
use the 6 heat range VX NGK platinums ...
Greg
Old Mar 20, 2002 | 11:05 AM
Casey's Avatar
Default Re: What plug gap should I use for 12:1 compression and which plugs? (Mike K)
is that for both of us Mike? thanks
Old Mar 20, 2002 | 11:26 AM
Mike K's Avatar
Default Re: What plug gap should I use for 12:1 compression and which plugs? (TypeRformewhenIB18)
I think running colder plugs is usually a crock of ****, to be quite honest.
I mean, yea.. at a certian point if you make enough power with your engine, you'll need to do it.. but fwiw.. my B20/B17 has 12.6:1 compression, JUN cams, SMS header, etc... I saw the best results with stock ITR plugs. THe BKR7E would foul too quickly.
Now if I was running 15 lbs of boost or a 150 shot, then I would look into another type of plug...
but for what it is, the stock ITR PFR6G-11 can't be beat.
it'll work well for 90% of you guys out there.
89si-rex
33
Oct 9, 2013 11:20 AM
charlieboyhonda
13
Jul 19, 2009 01:00 PM
123Four
Sep 22, 2007 03:28 PM
boosted-EG6
Dec 4, 2005 07:48 PM
crxsirvtec
12
Jan 27, 2004 12:46 PM
