Cranking the starter motor
Old Jan 7, 2006 | 05:33 PM
UNKNOWN_MEMBER's Avatar
Default Cranking the starter motor
What can cause starting the motor to lag? Like turning the ignition to get the start motor on it takes a while, like 2-10 seconds sometimes, sometimes it doesnt even start. Only thing i can think of a is a bad ground which i will check when i get home. but for now, what else can be the problem?
Old Jan 7, 2006 | 05:39 PM
old man neri's Avatar
Default Re: Cranking the starter motor (UNKNOWN_MEMBER)
ingnition switch a little screwy. Bad gound or hot lead. Battery a little dead, starting starting to die. The possibilities are almost endless.
Old Jan 7, 2006 | 08:25 PM
Default Re: Cranking the starter motor (old man neri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">ingnition switch a little screwy. Bad gound or hot lead. Battery a little dead, starting starting to die. The possibilities are almost endless.</TD></TR></TABLE> what do you mean hot lead?
Old Jan 7, 2006 | 11:38 PM
You have a bunch of cables that lead from the negative post of you battery to different parts of your chassis, transmition and engine. These are refered to as "grounds"
You also have a big cable leading from your positive post of your battery to your starter. That is what I was refering to as your main hot lead (I am sure there is a much better term for it). A lot of amps go through that cable, it needs to be in good condition as well as the connection points of that cable.
Old Jan 8, 2006 | 01:59 AM
could an alarm mess with it?
Old Jan 8, 2006 | 02:07 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote">could an alarm mess with it?</TD></TR></TABLE>
Not that I know of, unless it was drawing a lot of power (not likely). Maybe when whoever hooked it up spliced to some power he/she thinned out a connection from the battery.
I am by no means an alarm expert.
ddjmagic
Oct 28, 2017 05:33 PM
serr38
Jan 15, 2010 11:01 AM
badazzaccrd
May 29, 2004 10:05 PM
brinks
Sep 19, 2002 02:39 AM
JSpecwest
Dec 26, 2001 09:47 AM
