92 lude w/ h22a limp mode
I just got the car running and did the VTEC solenoid and pressure switch wiring. IT idles perfect but low end power is really sluggish but when i Hit vtec it seems fine. My ECU was wired for the knock sensor and Intake air bypass solenoid. (checked the ecu pinouts and the right color wires were there) I just drove a few miles and the car went into limp mode and it has no power. Anyone have any ideas?
I assume that you lengthened the wires for the o2 sensor to go into the downpipe. I would re-check your wiring for the o2 sensor. If one of those wires is touching or if you did a bad re-wire job...then that'll be ur problem. Doing your same swap btw.
No_Limits_Accord
Jul 9, 2008 06:44 PM
allwhitehonda
Aug 17, 2004 10:06 AM
