Alarm siren no longer works.
Old Jan 7, 2006 | 02:51 PM
JDM-EJ1's Avatar
Default Alarm siren no longer works.
I went out to my car the other day to show a buddy my progress on my car. My alarms siren worked fine then. I go out there today to putter around with it and I notice that my siren has became VERY quiet (you can hear it but, your ear has to be within a couple feet of it). My car sits under a car cover, everynight.
My siren is mounted at my firewall, directly behind my intake manifold. It had rained for the past couple of nights. It still works fine, but the siren doesn't do what it is made to do? Does this just sound like a bad siren?
Old Jan 7, 2006 | 05:09 PM
1995Ex_Sedan's Avatar
This happened to my sister, sounds stupid, asking it now, but its it full of water? Splice a line directly to the battery. See if it sounds the same.
Old Jan 7, 2006 | 05:16 PM
OMG THE GOGGLES's Avatar
Default Re: (1995Ex_Sedan)
Same thing happened to me on 2 cars, just replaced it. Its worth the 10 or so dollars to just replace.
Old Jan 7, 2006 | 11:08 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Ex_Sedan &raquo;</TD></TR><TR><TD CLASS="quote">This happened to my sister, sounds stupid, asking it now, but its it full of water? Splice a line directly to the battery. See if it sounds the same.</TD></TR></TABLE>
What if it sounds normal, than what?
Old Jan 7, 2006 | 11:29 PM
Default Re: (JDM-EJ1)
On both of my cars, I would have instances where it would work fine one day, then not the next. Do yourself a favor in the long run and order anew one, along with a piezo siren for the interior to make their ears bleed. Christ, the piezo ones only cost a few dollars on Ebay. Do a search for "513T" by DEI. Those are for interior, exterior any DEI or similar brand will do.
Old Jan 8, 2006 | 12:30 AM
JDM-EJ1's Avatar
Default Re: (gasper4486)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gasper4486 &raquo;</TD></TR><TR><TD CLASS="quote">On both of my cars, I would have instances where it would work fine one day, then not the next. Do yourself a favor in the long run and order anew one, along with a piezo siren for the interior to make their ears bleed. Christ, the piezo ones only cost a few dollars on Ebay. Do a search for "513T" by DEI. Those are for interior, exterior any DEI or similar brand will do.</TD></TR></TABLE>
Can I just splice the horn wires together? Like, wire up one horn the normal way, and tap the other siren into the existing wires?
Old Jan 8, 2006 | 02:58 PM
JDM-EJ1's Avatar
Default Re: Alarm siren no longer works. (JDM-EJ1)
Anyone else on this? Could I wire up 2 sirens to my existing alarm? Like, tap another siren into my existing siren?
Old Jan 9, 2006 | 08:33 AM
suspendedHatch's Avatar
Yeah you can split them off if you have two sirens that don't draw much power, like a piezo and the DEI siren. If it's too much draw (sounds quieter), then get a relay and run the brown siren wire to 86, 85 to ground. Constant 12V to 87, and branch your sirens off of 30.
The siren's probably full of water. Mount it facing downward. The water wont pool up, and it will sound louder too.
Old Jan 9, 2006 | 09:16 AM
Dy-JDM-Hatch's Avatar
sound like there is water in the siren
Old Jan 9, 2006 | 09:55 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">I went out to my car the other day to show a buddy my progress on my car. My alarms siren worked fine then. I go out there today to putter around with it and I notice that my siren has became VERY quiet (you can hear it but, your ear has to be within a couple feet of it). My car sits under a car cover, everynight.
My siren is mounted at my firewall, directly behind my intake manifold. It had rained for the past couple of nights. It still works fine, but the siren doesn't do what it is made to do? Does this just sound like a bad siren?</TD></TR></TABLE> I am going to agree with most of the people here, it sounds like water in the siren, and even if it is facing down, it is not an uncommon problem for the "inside" cone to fill up with water, unscrew siren, [do not disconnect yet] check and see if its water, [dump it] if there was any water in it when you "dumped it" try it and see how it works, if it works, carefully drill a 1/8" hole in what will be the low point of the inside cone once remounted, it will allow water to drain, I have done that fix more then a few times.
If the siren still will not work, disconnect it and as suggested just connect it to the batt. for a sec. if it still does not work, replace it, however if it does work, you will need to check the wiring, and if that is good, you have a problem with the alarm brain. 94
Old Jan 10, 2006 | 09:57 PM
JDM-EJ1's Avatar
Default Re: Alarm siren no longer works. (fcm)
Thanks for all the help guys!!
rancidhooligan
Audio / Security / Video
Sep 4, 2007 08:37 AM
mugenpowered
16
Aug 27, 2006 09:32 AM
Shinbo
May 17, 2005 02:11 PM
DrewQ1
Aug 2, 2004 01:20 PM
Filliam H. Muffman
20
Dec 28, 2003 05:50 PM
