nos
ok dude get a dry shot 75 cheap as expletive no need for fuel system upgrade safe on any motor and any transmisson honda makes (car wise) its an old topic and make sure u live ur life a 1/4 mile at a time and NEVER call it boost, cheat, spray or nitrous always call it NAWZ
just quick question... i have seen pics of the nitrous injectors going in through the air intake.... is that for wet and dry?
also wher does direct shot go through?
SORRY I KNOW ITS STUPID QUESTIONS
direct port goes into the intake manifold 1 injector per cylinder right infront of the intake ports
dry and wet are intake piping or stock intake
but theres a new thing u should get for ur car rice injection or soy sauce injection 3x better than nawz!!!!!!!
^Coming from the guy who has the NX bottle as his avatar. Cant you get a sraight answer on h-t these days. BTW I use soy in my intertcooler srayer kit because It has nearly double the heat exchanging properties as n2o.
Like he said a cheap 75 is all you need. You clutch might start to slip though. (My friends did w/ a 75 shot)
here is what i would do go to the conner of the page, top right, and hit the search then type in nos or n02 and hit the archive button, then hit search you will come up with so many topics its not even funny.
I will answer one question and the other you can find on the search. Yes you can on any stock engine, however you must not use to much and not use it when the motor is cold. N02 is basically like a turbo's boost on demand but when used wrong it is not safe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2CivMan »</TD></TR><TR><TD CLASS="quote">^Coming from the guy who has the NX bottle as his avatar. Cant you get a sraight answer on h-t these days. BTW I use soy in my intertcooler srayer kit because It has nearly double the heat exchanging properties as n2o.
Like he said a cheap 75 is all you need. You clutch might start to slip though. (My friends did w/ a 75 shot)</TD></TR></TABLE>
lmao it used to look like it had purge valves for eyes and purged like evry second but it stopped wrking
1990 CRX Si
26
Feb 9, 2006 04:56 PM
mr.roboto
Sep 19, 2005 01:45 PM
