need advice on custom exhaust.
Alright, i've been thinking about having a quiet, but yet throaty exhaust made.
My setup i have in thought right now is:
cat > longest resonator that can fit > S bend > then to a obx twinloop muffler (tested to be 2.5" straight through). All with 2.5" OD piping and 2.5" OD in/out resonator.
Will the resonator be able to quiet down the sound a lot? How exactly does the resonator work?
Yes i already know that the stock cat and collector will bottleneck it. But i'm doing one step at a time.
Thanks!
Thanks!
http://www.we-todd-did-racing....5NTQx
Sound clip taken from behind the car about 15 feet. There is really no raspy quality, just some static from the recording mic being over-powered. It is really pretty quiet at cruising speeds.
2.5" mandrel bent exhaust
2.5" x 22" magnaflow resonator
8 x 5 x 14" magnaflow straight through muffler
2.3 liter
cammed nonVTEC (that's why the idle is lopey)
11.7 compression
Pirate
2.3 liter
11.7 compression
Pirate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Phil »</TD></TR><TR><TD CLASS="quote">Why would you measure exhaust piping by OD?</TD></TR></TABLE>
Nobody measures pipe by ID. Only OD and wall thickness. You're on your own to be conscious of the ID.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreludeX24 »</TD></TR><TR><TD CLASS="quote">Alright, i've been thinking about having a quiet, but yet throaty exhaust made.
Thanks!
you can go with 1 long resonators, or you can go with 2 shorter resonators, crammed in whereever they fit. (i believe you can use a shorty resonator on the transverse part of the exh.)
Thanks!
</TD></TR></TABLE>you can go with 1 long resonators, or you can go with 2 shorter resonators, crammed in whereever they fit. (i believe you can use a shorty resonator on the transverse part of the exh.)
B19CivicHB
Aug 28, 2002 04:13 PM
