Water cover outlet (coolant return) question
Okay, it's part #7 I'm wondering about:
I would like to know if that part from an EF (d15b2 & d16a6) will work on a d16z6 head. The reason I'd like to know is because the EF part faces the passenger side, while the Z6 part faces mostly forward. With a del sol rad in my car, the hose is almost kinking because of the wierd angles.
Thanks for any help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 »</TD></TR><TR><TD CLASS="quote">You can swap them and use the A6/B2 hose, or keep it and get a Z6 del sol upper radiator hose.</TD></TR></TABLE>
By 'swap them' you mean the aluminum part, right? I just want to be perfectly sure. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">
By 'swap them' you mean the aluminum part, right? I just want to be perfectly sure. Thanks.</TD></TR></TABLE>
Yea, the part that bolts to the head. Use the grey sealant or HondaBond.
Fibercation
14
Jun 4, 2008 05:41 PM
JayDM-hatch
Jan 17, 2008 07:29 PM
_gurusan_
Oct 1, 2005 07:57 PM
90civichb
Apr 3, 2004 08:52 AM
