What would be the best rad hose for my swap?
I have an EG hatch and I am doing a b18b swap... I am using a del sol radiator which has the bigger inlet and outlet tubes for the B series engine. What is the best rad hose to use for this swap??? Do del sol hoses work ok??
Re: What would be the best rad hose for my swap? (JayDM-hatch)
ooo shiit i forgot b18b... non vtec... yea i used mine on B16. i think the upper radiator hose goes to the same place though doesnt it?? im not too familiar with b18b's. its on the left side behind the head on the intake right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDM-hatch »</TD></TR><TR><TD CLASS="quote">Well on the non-vtec head the top hose goes directly under the cam seal in front of the distributer.</TD></TR></TABLE>
oooo didnt know that.... ive only ever had vtec b series. use non vtec integra hoses... they should come off the radiator and to the correct spot.
Re: What would be the best rad hose for my swap? (93egSLEEPER)
I am not sure if it will line up right with the tube on the rad because it is a half rad rather than the full width integra one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDM-hatch »</TD></TR><TR><TD CLASS="quote">I am not sure if it will line up right with the tube on the rad because it is a half rad rather than the full width integra one.</TD></TR></TABLE>
both have the same coolant opening on the ;eft side of the radiator. if there is any difference its very small and wont make a difference. I used my stock d16z6 radiator with my b16 swap... just had to buy the hose to match the motor.
no problem... like i say im not 100% sure so let me know if i was right or not. my bad in advance if you get the wrong part.
CRXified
10
04-26-2005 06:54 PM
