Abs air bleed? How?
Old Jan 6, 2006 | 09:33 AM
PARADOX_sf's Avatar
Default Abs air bleed? How?
Hello!
I have euro EG6 Civic. It have ABS system but have some problem with it. I check error code. Code is 1. I think that there is some air in system. Is there way to bleed air from ABS but without to use Honda ALB ckecker?
Thank you!
P.S. I have "home made" Bleeder-T wrentch.
Old Jan 6, 2006 | 09:47 AM
Luserkid's Avatar
Default Re: Abs air bleed? How? (PARADOX_sf)
Can you show pics of your home made T wrench? Mainly thats the tool you need, also you need to know how to cycle. I hate doing abs because of that.
Old Jan 8, 2006 | 01:11 PM
PARADOX_sf's Avatar
Default Re: Abs air bleed? How? (Luserkid)
Hi.
Just remove charcoal canister (only for air bleeding) and use 3mm silicon pipe + wrench N9 . This is my T-tool.
I know what is ABS air bleeding procedure but how can i do it without ALB cheker? Is there some way?
Old Jan 10, 2006 | 01:01 PM
PARADOX_sf's Avatar
up!
eagle458
Feb 3, 2014 10:24 PM
Daniel M.
Mar 4, 2006 04:56 AM
lilcaliplayany
Apr 12, 2004 06:14 PM
onehot34
Jul 24, 2003 08:08 PM
$pecial K
Jun 10, 2003 07:40 PM
