Subject: Oil leak; Reason for post: Need help!
Old Mar 19, 2002 | 06:00 PM
D1ANCER's Avatar
Default Subject: Oil leak; Reason for post: Need help!
I just located the sorce of my oil leak. It is were the head meets the block. I have a 1st Gen B16A1 in a 94 Civic DX. The head was taken off before the motor was put in to replace the pistons and inspect. Could there be any other possible problem that needs to be taken care of when the head is off again? I just hope this is the last time I have to do this, so I would like to know everything I should look for. Also, is there any way to tell if the block is worped? I just want to know what you guys know. Please help a fellow import fan out.
Old Mar 19, 2002 | 06:05 PM
ExospeedAMcrx's Avatar
Default Re: Subject: Oil leak; Reason for post: Need help! (D1ANCER)
was the block rehoned/machined to fit the new pistons?
did they just install the pistons without rebuilding the block?
Wil
http://www.exospeed.com
Old Mar 19, 2002 | 06:09 PM
D1ANCER's Avatar
Default Re: Subject: Oil leak; Reason for post: Need help! (exospeedAMcrx)
I was told what he did was the equal to the honing, but all he really did was take out the old pistons, put new pistons, rods, and rings in the block.
When putting a head gasket on, should I put some sort of sealant? If so, what and where?
How hard is it to take off the head once it is in the car?
Old Mar 20, 2002 | 01:19 PM
3rdGteg's Avatar
It's pretty easy to take the head off the block even with the engine still in; the only pain in the a$$ part is taking the intake manifold off w/ the head still intact. If I were you, I'd get the block and head resurfaced to ensure both mating surface will be straight when installing the new headgasket. Hth
Old Mar 20, 2002 | 07:12 PM
AmauryR's Avatar
When installing the new headgasket, use some cooper-spray sealer (pepboys, autozone, etc...) before installing the gasket on both sides. Then install it, thats what I did w/ my B18C1, so far, no probs.
methos713
May 30, 2008 07:26 AM
cobaltss
11
Dec 12, 2007 12:12 PM
acro_acura94
Mar 7, 2005 08:42 AM
DB2#308
May 17, 2004 11:54 PM
