Where can i find turbo f22 manifold for cheap?
Old Jan 5, 2006 | 12:11 PM
kroze's Avatar
Default Where can i find turbo f22 manifold for cheap?
as a matter of fact, where can i find them altogether :/
i can only find them in turbo kits that cost like $3k. does anyone sell em just by itself?
Old Jan 5, 2006 | 01:42 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Where can i find turbo f22 manifold for cheap? (kroze)
1g DSM manifolds will bolt up if you have the F22A. As for f22 B's, check out SFP for a great A/C compatible mani.
Old Jan 5, 2006 | 03:51 PM
cantaffordaccord's Avatar
i have an f-max manifold hot jet coated in black pm me for more info
Old Jan 5, 2006 | 04:23 PM
chile's Avatar
Default Re: Where can i find turbo f22 manifold for cheap? (cantaffordaccord)
if you buy the dsm manis, remember to redrill them to fit....any exhaust shop can do it...might want to get it port matched also...
Old Jan 5, 2006 | 05:10 PM
JonnySBeee...'s Avatar
spoolin performance can fab a log style manifold for around 300 i belive, but other than that a 1g DSM fits as stated, but redrilling is needed.
Old Jan 5, 2006 | 05:16 PM
chile's Avatar
Default Re: Where can i find turbo f22 manifold for cheap? (mmhmm)
go to a junkyard and look for a 1st or 2nd gen eclipse/talon/laser and grab everything (mani, turbo, bov, smic, j-pipe, injectors (look for blue topped 450cc, i think those are 1st gen)...then find someone selling oil lines..and coolant lines...you should be able to get a mani and turbo for around $150, depending on the junkyard...otherwise, egay sometimes has good deals but ask a LOT of questions first...
Old Jan 5, 2006 | 05:57 PM
kroze's Avatar
Default Re: Where can i find turbo f22 manifold for cheap? (chile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chile &raquo;</TD></TR><TR><TD CLASS="quote">go to a junkyard and look for a 1st or 2nd gen eclipse/talon/laser and grab everything (mani, turbo, bov, smic, j-pipe, injectors (look for blue topped 450cc, i think those are 1st gen)...then find someone selling oil lines..and coolant lines...you should be able to get a mani and turbo for around $150, depending on the junkyard...otherwise, egay sometimes has good deals but ask a LOT of questions first...</TD></TR></TABLE>
thanks man! so it doesn't matter whether it's 1st or 2nd gen dsm for the manifold eh? if i get the manifold, what turbo will it work with other than the stock dsm?
what about those aftermarket dsm turbo manifold they're selling for on ebay. will it fit?
i have a 96 accord ex coupe vtec.
just to be sure, the ex model vtec is the f22a1 right?
Modified by kroze at 7:08 PM 1/5/2006
Old Jan 5, 2006 | 06:12 PM
v4lu3s's Avatar
RTFM
you do NOT have an f22a engine so the DSM stuff will not work
yo uhave an f22b1.
Old Jan 5, 2006 | 08:31 PM
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">you do NOT have an f22a engine so the DSM stuff will not work
yo uhave an f22b1.</TD></TR></TABLE>
you CAN use dsm manifolds, they fit bro. search youll find it
Old Jan 5, 2006 | 09:35 PM
i_kick_turtles's Avatar
Default Re: (mmhmm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmhmm &raquo;</TD></TR><TR><TD CLASS="quote">
you CAN use dsm manifolds, they fit bro. search youll find it </TD></TR></TABLE>
No. The dsm manifolds will not fit an f22bx.
The f22bx has ports like this: O-OO-O.
The dsm and f22ax are like: O-O-O-O.
Old Jan 6, 2006 | 03:55 AM
v4lu3s's Avatar
RTFM
Default Re: (mmhmm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmhmm &raquo;</TD></TR><TR><TD CLASS="quote">you CAN use dsm manifolds, they fit bro. search youll find it </TD></TR></TABLE>
sorry you are wrong.
I dont need to search on here I jsut need to walk out to my shop and look at teh 20+ engines sitting around to know that f22a series engines have different ports than f22b series engines....
Old Jan 6, 2006 | 04:33 AM
chile's Avatar
they will not fit F22B's....
Old Jan 6, 2006 | 05:19 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: (chile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt4cPwn35 &raquo;</TD></TR><TR><TD CLASS="quote">As for f22 B's, check out SFP for a great A/C compatible mani.</TD></TR></TABLE>
Old Apr 26, 2015 | 05:10 PM
Maav68's Avatar
What holes have to be re-drilled?
QUOTE=JonnySBeee...;19402143]<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">you do NOT have an f22a engine so the DSM stuff will not work
you CAN use dsm manifolds, they fit bro. search youll find it [/QUOTE]
Old May 1, 2015 | 10:54 AM
AK_CRX's Avatar
This is going to get confusing with the contradicting info. I can say for certain, from experience, that the DSM manifolds are only compatible with f22a engines. DSM manifolds do not, repeat do not fit the f22b sohc engines, this is very basic, very well documented info.
Old May 1, 2015 | 12:01 PM
TheMuffinMan's Avatar
He knows where you live!
9 year thread bump...that was necessary
Honda owner
Jun 3, 2006 04:03 PM
mamaboy
May 19, 2004 01:17 PM
7808
Feb 13, 2004 04:33 AM
hoggy
Sep 25, 2003 09:31 PM
