What else to replace while doing the Shocks/Struts?
Old Jan 5, 2006 | 11:34 AM
bluskye's Avatar
Default What else to replace while doing the Shocks/Struts?
So, i won these new tokico illumina shocks/struts for $175 on ebay from a guy who got rid of his car before putting them on .
The struts/shocks are being used with OEM springs, overkill i guess, but for $175 cant beat it. What other parts are suggested to replace while doing the swap? front and rear strut/shock mounts? what else?
Thanks in advance.
Old Jan 5, 2006 | 11:47 AM
Import Driver's Avatar
Default Re: What else to replace while doing the Shocks/Struts? (bluskye)
Sometimes you end up needing to cut the mounting bolts out because the are froze to the bushings. In which case you would need to get new bolts, and possibly new bushings.
That is all I can think of. Have fun.
I sent you a PM.
Old Jan 5, 2006 | 11:51 AM
bluskye's Avatar
Default Re: What else to replace while doing the Shocks/Struts? (Import Driver)
Sweet, nothing my IR TNT impact wrench cant handle.... 1000lb-ft burst torque.... mmmm.
Old Jan 5, 2006 | 12:26 PM
kroze's Avatar
replace all bushings. lower ball joints, upper control arms, sway bar bushings, inner & outer tie rods. they're like $139 shipped for the whole kit and it makes your car ride like brand new again.
Old Jan 5, 2006 | 12:29 PM
bluskye's Avatar
Default Re: What else to replace while doing the Shocks/Struts? (kroze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kroze &raquo;</TD></TR><TR><TD CLASS="quote">replace all bushings. lower ball joints, upper control arms, sway bar bushings, inner & outer tie rods. they're like $139 shipped for the whole kit and it makes your car ride like brand new again.</TD></TR></TABLE>
I got that kit already
I was just asking what to replace strictly related to the shocks/struts.
Old Jan 5, 2006 | 12:54 PM
kroze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluskye &raquo;</TD></TR><TR><TD CLASS="quote">
I was just asking what to replace strictly related to the shocks/struts.</TD></TR></TABLE>
errr...strictly related to shocks & strut? lol.
let's see: shocks, struts, springs. /thread.
useless. don't title the thread asking what else to replace while doing struts & shocks.
Old Jan 5, 2006 | 01:03 PM
bluskye's Avatar
There's more to it, on any car... I want to know if it is suggested to replace the strut/shock mounts.... Have you ever replaced shocks on any car? struts/shocks connect to mounts, which then connect to the chasis in some form or fashion.
Old Jan 5, 2006 | 03:13 PM
need_a_h22's Avatar
whats the name of this kit? Does tasauto.com have it? If not where is it at because I think I need one.
Old Jan 5, 2006 | 03:17 PM
iam7head's Avatar
Default Re: What else to replace while doing the Shocks/Struts? (ganjavol)
check the upper rubber mount, the piece gets hammer all the time.
check the bumpstop, not very likely need replacement if your car is stock height.
i think the bolt is pressed into the top hat, unless it's stripped, don't bother.
the top hat nuts you could replace if they are rounding off, make sure get some automotive grade replacement, not home depot zinc construction stuff.
Old Jan 5, 2006 | 06:02 PM
kroze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ganjavol &raquo;</TD></TR><TR><TD CLASS="quote">
whats the name of this kit? Does tasauto.com have it? If not where is it at because I think I need one.</TD></TR></TABLE>
http://cgi.ebay.com/ebaymotors...wItem
they jacked up the price
Old Jan 5, 2006 | 06:58 PM
bluskye's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kroze &raquo;</TD></TR><TR><TD CLASS="quote">http://cgi.ebay.com/ebaymotors...wItem
they jacked up the price</TD></TR></TABLE>
No, another vendor has it for 139.99 still :
Old Jan 5, 2006 | 07:05 PM
twobit's Avatar
sways/struts if possible
Old Jan 5, 2006 | 07:47 PM
BLKFLSH's Avatar
There is a lot of stuff you can check out while you're down there. suspension, brakes, and cv joint boots. Might as well clean the back side of the wheels and rotate the tires.
DSMRacing
Jun 24, 2006 02:40 PM
elpiar
Suspension & Brakes
Apr 25, 2005 06:03 PM
businessmanph
Jan 30, 2005 01:01 AM
osuperjohno
Dec 30, 2004 05:43 AM
RUBZERK
Mar 20, 2004 04:05 AM
