1991 accord RED Battery light stays on?
Old Jan 5, 2006 | 11:11 AM
tedog69er's Avatar
Default 1991 accord RED Battery light stays on?
1991 accord RED Battery light stays on!! What can cause this? thanks
Old Jan 5, 2006 | 11:48 AM
Honda-Master's Avatar
a faulty alternator
Old Jan 5, 2006 | 11:49 AM
iam7head's Avatar
Default Re: (Honda-Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Master &raquo;</TD></TR><TR><TD CLASS="quote">a faulty alternator</TD></TR></TABLE>
the number one cause, but i could be something else.
do you have a multi meter?
Old Jan 5, 2006 | 12:18 PM
tedog69er's Avatar
Default Re: (iam7head)
Yes I do have a multi meter!
Old Jan 5, 2006 | 02:19 PM
P_Adams's Avatar
Default Re: 1991 accord RED Battery light stays on? (tedog69er)
Set your Multimeter to read 12vdc and test between the battery terminals
first with the engine off.
It should read between 12.2 and 12.5 volts (Battery steady state voltage)
Second with Engine running:
It should read between 13.8 and 14.2 volts (Alternator Output voltage)
P
Old Jan 5, 2006 | 03:01 PM
sweet7d340's Avatar
try replacing the ELD not real sure but I think it is in the under hood fuse box if an alternator does not fix your problem
Old Jan 14, 2006 | 11:26 AM
tedog69er's Avatar
What is an ELD? My alt. Seems to be putting out the right amount of juice.
Old Jan 15, 2006 | 09:32 AM
tedog69er's Avatar
can anyone help me with this?
Old Jan 15, 2006 | 09:39 AM
noobie's Avatar
if you don't have the tools to test the charging system, take it to sears and have them chk it out for you,,,,,but it sounds like a bad alternator
Old Jan 15, 2006 | 09:54 AM
tedog69er's Avatar
Default Re: (noobie)
I had a multi meter and check it with your perimeters and it was a little over around 13.9 to 14.2 with engine running. does bog down alittle when light and things are turned on
Old Jan 15, 2006 | 10:30 AM
YeuEmMaiMai's Avatar
ELD = Electrical Load Detector. It is normal for alt voltage to drop at idle when you load down the engine with lights and etc..........
Old Jan 18, 2006 | 05:14 PM
hondadude's Avatar
Go to the dealership and get a 'brush pak' for the alternator, swing the alt up as far as it will go; disconnect the battery, remove the insulator from the alt where the battery cable connects, then the 8mm nuts on the back of the alt. the shroud will come off and you will see 2 phillips head screws holding the brush pak on.
RJay64
Jul 15, 2014 10:26 AM
haywyre
Oct 9, 2008 12:27 PM
LCDeuce
Sep 7, 2008 04:56 AM
idriveadelsol7
Dec 11, 2005 04:05 AM
EGmikeH22
Sep 1, 2005 09:57 AM
