gsr head bolts or si head bolt
Old Jan 5, 2006 | 11:02 AM
Ruben19's Avatar
Default gsr head bolts or si head bolt
im working on a b16a2 head and a b18c1 block
what head bolts should i use?
i already installed the b16a2 bolts
but my friend told me to use the gsr bolts because they are longer than the si bolts.
is that true
Old Jan 5, 2006 | 11:16 AM
skunked's Avatar
Default Re: gsr head bolts or si head bolt (Ruben19)
Use the head bolts according to the shortblock you are using. In your case the B18C are the correct headblots because your running a B18C shortblock.
Old Jan 5, 2006 | 12:42 PM
Ruben19's Avatar
what about if i already installed the si bolts
would this make a difference.
Old Jan 5, 2006 | 01:57 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: (Ruben19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 &raquo;</TD></TR><TR><TD CLASS="quote">what about if i already installed the si bolts
would this make a difference.</TD></TR></TABLE>
Take them out and use gsr bolts
Old Jan 5, 2006 | 02:06 PM
skunked's Avatar
Personally I would pull them out and replace them with new B18C head bolts and a new headgasket.
Old Jan 5, 2006 | 05:00 PM
Surubasi00's Avatar
take them out
they are too short
Dave
Old Jan 5, 2006 | 05:48 PM
Ruben19's Avatar
they r out
i can tell the difference.
gsr bolts are 1''longer.
Ruben19
Jan 5, 2006 04:30 PM
B1Boosted
Feb 27, 2004 09:47 PM
ELSpool
Jul 28, 2003 11:21 AM
neumonik
Nov 28, 2001 07:55 PM
