Golden Eagle LS-VTEC Kit + Turbo Question
Old Jan 5, 2006 | 01:12 AM
OMG B16's Avatar
Default Golden Eagle LS-VTEC Kit + Turbo Question
I'll be ordering the GE LS-vtec conversion kit for my car in a few days i was wondering if the oil sandwich has 2 outputs for turbo and vtec, of if you have to run the turbo oil supply from somewhere else?
Also Should i go with the 82mm bore kit? My block will be 81.5mm.
Thanks alot.
Old Jan 5, 2006 | 05:48 AM
blackeg's Avatar
Default Re: Golden Eagle LS-VTEC Kit + Turbo Question (Sick00SiCoupe)
yes the plate has 1 for the vtec and another 1/8 for the oil feed. stay 81.5 if you are gonna boost on stock sleeves imo
Old Jan 5, 2006 | 06:27 AM
GDM Z28's Avatar
Default Re: Golden Eagle LS-VTEC Kit + Turbo Question (blackeg)
with a 81.5mm block you can use a stock oem head gasket. thats what i use to run because i loved the oem ones. but if your ordering the whole kit (which isnt needed) go with 81mm
Old Jan 5, 2006 | 01:11 PM
OMG B16's Avatar
Thanks alot guys...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">yes the plate has 1 for the vtec and another 1/8 for the oil feed. stay 81.5 if you are gonna boost on stock sleeves imo</TD></TR></TABLE>
I wasnt talking about the bore, i was talking about the HG. But thanks
Old May 31, 2006 | 09:20 PM
komat's Avatar
Default Re: (OMG B16)
i would not run the turbo feed on the same sandwish plate that feeds your head.
Old May 31, 2006 | 09:21 PM
Touge Tuning's Avatar
im pretty sure it says for 81.5mm to run the 82mm gasket.
Built4Battle
Oct 20, 2011 12:18 PM
integraracing91
Jul 16, 2007 07:19 PM
jdm2ltrcpe
Mar 13, 2007 02:51 PM
fake mugen power
Apr 22, 2005 08:41 AM
jfoster
Mar 14, 2005 08:33 PM
