Golden Eagle LS-VTEC Kit + Turbo Question
I'll be ordering the GE LS-vtec conversion kit for my car in a few days i was wondering if the oil sandwich has 2 outputs for turbo and vtec, of if you have to run the turbo oil supply from somewhere else?
Also Should i go with the 82mm bore kit? My block will be 81.5mm.
Thanks alot.
Thanks alot.
Re: Golden Eagle LS-VTEC Kit + Turbo Question (Sick00SiCoupe)
yes the plate has 1 for the vtec and another 1/8 for the oil feed. stay 81.5 if you are gonna boost on stock sleeves imo
Re: Golden Eagle LS-VTEC Kit + Turbo Question (blackeg)
with a 81.5mm block you can use a stock oem head gasket. thats what i use to run because i loved the oem ones. but if your ordering the whole kit (which isnt needed) go with 81mm
Thanks alot guys...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">yes the plate has 1 for the vtec and another 1/8 for the oil feed. stay 81.5 if you are gonna boost on stock sleeves imo</TD></TR></TABLE>
I wasnt talking about the bore, i was talking about the HG. But thanks
