delsol swap
hey guys i have a ?.... i am putting a b series motor in to my delsol and i am hearing that i have to cut my shift linkage to make it work..wat i dont get is that isnt the DOHC shift linkage on a GSR the same as a shift linkage on a DOHC on a b16 delsol..... so if i am rite cani use the same shift linkage on a gsr.... but if i am wrong can you guys tell me how to cut it..... pictures would help alot... by the way i have a sohc in my delsol.... and putting in a b20 vtec motor... thanks for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x_outlaw_x »</TD></TR><TR><TD CLASS="quote">you need actual del sol shift linkage...integra wont work because of the shorter chassis</TD></TR></TABLE>
You need a del sol VTEC shift linkage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 »</TD></TR><TR><TD CLASS="quote">You need a del sol VTEC shift linkage</TD></TR></TABLE>
yup. they are like 80 bucks form the dealer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">
yup. they are like 80 bucks form the dealer.</TD></TR></TABLE>
Yes they are. And take it from me just buy them new. I looked for months trying to find a used set and I couldn't.
and like 200 from Inline 4.
the SOHC del sol shift linkage is acutally too short for the B-series motor. When i did my gsr swap, i too had a hard time locating a used DOHC del sol shift linkage, so i opted to cut it and extend it. I DON'T RECOMMEND THIS. so i just got one from the dealer.
The OTHER difference between a GSR shift linkage and a DOHC del sol is the bends in them. the del sol has a higher center console then the integras, hence the bends in the linkage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whoDAT »</TD></TR><TR><TD CLASS="quote">
The OTHER difference between a GSR shift linkage and a DOHC del sol is the bends in them. the del sol has a higher center console then the integras, hence the bends in the linkage.</TD></TR></TABLE>
I thought one of the bends was to clear that big *** x member or whatever you want to call it. When I tried to use a b series linkage the linkage hit the x member.
turbodelsolb16a2
Jul 28, 2013 11:37 PM
AzntaggeR
Dec 23, 2003 09:34 PM
