Where is the IAC valve located?!!!!!!!!!!!
Old Jan 4, 2006 | 07:59 PM
r1de4life's Avatar
Default Where is the IAC valve located?!!!!!!!!!!!
Where is the IAC vavle located?
Old Jan 4, 2006 | 08:39 PM
Rosko's Avatar
Default Re: Where is the IAC valve located?!!!!!!!!!!! (r1de4life)
right next to the throttle linkage on the manifold (to the right). It has an electrical connector and two hoses connected to the bottom of it.
Old Jan 4, 2006 | 09:05 PM
lude98SH's Avatar
Default Re: Where is the IAC valve located?!!!!!!!!!!! (Rosko)
Look in the center of your block and look directly back. Its located directly in the center on your intake manifold. There are two bolts holding it onto the manifold. One is longer than the other, so remember which goes where. Be careful not to make a mess and have a rag handy when disconecting those two hoses because they have antifreeze in them.
SnailSlowDelSol
Feb 21, 2016 09:26 PM
RiversideS13
Jul 18, 2007 11:08 AM
r1de4life
Jan 4, 2006 09:06 PM
alleyezonme
Dec 31, 2005 06:58 AM
comptechgsr2000
May 13, 2002 09:15 PM
