my civic has a prob? at idle it starts sounding like its feeding gas then letting off then again etc
Old Mar 19, 2002 | 03:23 PM
civicracer1993's Avatar
Default my civic has a prob? at idle it starts sounding like its feeding gas then letting off then again etc
the idle speed goes up and down at idle somtimes. what could this be? its a DX 1.5 L SOHC civic HB 1989? my friends prelude does the same thing then stops after a while . what could this b? is it expensive to fix?
mike
Old Mar 19, 2002 | 03:27 PM
big pete's Avatar
Default Re: my civic has a prob? at idle it starts sounding like its feeding gas then letting off then again
check your vacuum lines
Old Mar 20, 2002 | 10:37 AM
Perfectionist's Avatar
How much up and down does it go?
Old Mar 20, 2002 | 10:52 AM
namechangeagain
Guest
Posts: n/a
sounds like a vaccum problem
Old Mar 20, 2002 | 10:56 AM
anotherslowDX's Avatar
I have had that problem before. It is a vaccuum thing. One of your lines may have a hole in it. That will mess up the idle. I have a 89 DX sedan. It isnt too bad to fix. It tends to cost more for the mechanic to find the problem rather than to fix the problem.
Old Mar 20, 2002 | 10:57 AM
jdmekcivic2eg's Avatar
MY CAR DID THE SAME THING.. I TOOK IT TO THE SHOP AND THEY CLEANED SOMETHING OUT BUT I FORGOT WHAT IT WAS CALLED. IT IS LOCATED BEHIND THE INTAKE MANIFOLD NEAR THE THROTTLE.. IDLE CONTROL VALVE? NOT SURE, ILL FIND OUT..
Old Mar 20, 2002 | 12:05 PM
Cryptopsy's Avatar
Check your EACV. (I believe 1989 is F/I right?) Its located behind the F/I near the firewall. Take it, and the hoses off and check to see if the mesh screen is clogged up with carbon and ****. If so, take some carb cleaner and some small rags and q-tips and clean it up. You can even spray a liberal amount into the EACV to get behind the mesh....use compressed air to blow the carb cleaner out before re-connecting. Re-connect and try again. If its still acting shitty, well, hey, at least you cleaned your EACV. The vacume problem sounds legit also....
[Modified by SoulflyCRXsi, 3:08 PM 3/20/2002]
Old Mar 20, 2002 | 12:06 PM
well i hear u can spray some fluid on the vacuum lines and if it leaks the idle will rev up or somethin.. i forget what fluid it was?? starter fluid or something?? any ideas.
thanks
mike
Old Mar 20, 2002 | 12:07 PM
Cryptopsy's Avatar
In your case, you have a fast idel control valve, located under the TB. I Think with the 89-91, they have a EACV. (Electronic air control valve) which I previously explained how to clean. There is no need to take a car to the shop to have the EACV or FICV cleaned...its easy stuff.
Old Mar 20, 2002 | 02:31 PM
89 CRX SI's Avatar
Carb cleaner works well for this. Spray it on all connections and pipes your idle will jump up quite a bit if there is a leak where you sprayed it. Then Duct tape... JK also duct tape your motor mounts adds strenth.. JK
peterislazyek9
Jan 26, 2008 08:47 PM
BOOSTED_JDM_DB8
Feb 3, 2006 01:01 AM
stump7117
Mar 27, 2005 09:06 PM
4gen
Jan 11, 2004 05:28 PM
