How much do YOU trust your Autometer A/F gauge?
We finally got around to taking some video clips of actual comparisons between the (in)famous Autometer A/F guage VERSUS a true wideband O2 unit.
You'll notice in the video clip that even at idle, how WAY FAR off the Autometer gauge shows your a/f being. You'll see that on the WB display, the A/F sits pretty rock steady at 14.7, whereas the Autometer sweeps back and forth like crazy.
Keep in mind that this is only at IDLE.. the difference is even more apparent while driving.
I'll see we can get another clip with the car in motion at a later date.
http://www.c-speedracing.com/temp/autometervswb02.mpg
Enjoy.
Enjoy.
Not necessarily... you can pick up a Motec unit for around $1300 now. The one shown in the mpg is a custom built WB02 unit from the DIY community. We've compared its' accuracy and verified it on a dynojet dyno wideband and a motec plm unit.
there is also a company in AUSTRALIA that has a kit that will cost you around $200. there are several people that have bought it and are currently putting it together or gettign ready to test and compare.
i think the most ACCURATE A/F you can buy is the HALMETER unit with its W/B O2 sensor for $180.
ive heard alot of good stuff about them.
Entire kit (unassembled) shipped to calif=$151. Requires assembly and the following Oxygen sensor@$117.75: Partsbin Total kit-assembly time = $268.75. Not too shabby for a "True" wideband.
You might consider one of the cats that SMSP is developing or probably already has out. It has an extra bung built in it for an O2 sensor.
https://honda-tech.com/zerothread?id=144608
[Modified by SpecR_EK, 4:24 AM 3/20/2002]
dont trust it , i almost blew my motor becuase i was told they are reliable, well i found out on the dyno. i was running hella lean and the meter said i was hella rich , so it was nowhere even close.
So I trust it just about NONE.
Will
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
i wouldn't.... my halmeter gave me a "ballpark" reading compared to the wideband at the dyno. the halmeter indicated 2 bars rich when i was at 15 to 1! ouch.... i guess it's just a colorful light.....
Autometer is useful for tuning closed-loop stuff, because that is what the ECU sees. Helps a lot for tuning perfect idle, etc. Else it's just a light show.
yea it looks pretty at night and when people roll u on me think im a space shipor some **** . . . . . effectiveness for tuning . . . 0, none , nada.
and yes i have the autometer , i hear now its not the greatest , , go figure.
What is probably happening is the ECU is doing a very good job of keeping the A/F at 14.7 so the wide band unit is getting a steady reading, the standard O2 sensor is so sesitive round the 14.7 mark that it is crazily flicking back and forth with slight variations in A/F
Enjoy.
Enjoy.
[Modified by HardHead42, 6:42 PM 3/21/2002]
Lei Siew Long
Nov 16, 2001 01:48 PM
