Ok Guys, Need some help choosin block/crank for LS Vtec setup
Old Jan 4, 2006 | 11:53 AM
Topdawgg's Avatar
Default Ok Guys, Need some help choosin block/crank for LS Vtec setup...to bore or not to bore?
Ok, heres my predicament...
I have a b18a block that I just took in to get machine work done on, and when they checked the cylinders, he said that it needs to be bored out quite a bit... My crank is perfect he said...
I originally wanted to keep STD bore with my block, just to be stronger..
I have a set of eagle rods for a b18 block..
So heres my question, should I rip apart a b17 block I have kickin around, that has a spun bearing... and use my b18a crank and rods in IT,
OR..... Bore my b18 block out to correct those bad cylinder walls?
Modified by Topdawgg at 1:19 PM 1/4/2006
Old Jan 4, 2006 | 11:58 AM
onemanlan's Avatar
Bore it out, fill the block, and reap the rewards
Old Jan 4, 2006 | 12:16 PM
andysila's Avatar
Get the b18 sleeved.
if you use your b17 block w/ an LS crank/rods, wouldnt you need a deckplate?(correct me if im wrong)...
Old Jan 4, 2006 | 12:20 PM
Topdawgg's Avatar
im not gonna be sleeving...
and i dont know if i need anything to run the LS crank/rods.. thats why im askin
Old Jan 4, 2006 | 01:23 PM
nos51's Avatar
Default Re: (Topdawgg)
the b17 block is liek the b16a block its a little shorter,unlike the b18 blocks....so no you just cant throw everything in from the ls
Old Jan 4, 2006 | 01:29 PM
Topdawgg's Avatar
so my only option is to find another b18 block, or bore this one out
Old Jan 4, 2006 | 01:35 PM
tokesGTR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">so my only option is to find another b18 block, or bore this one out</TD></TR></TABLE>
Yes. Don't get hung up on wanting standard bore so bad, Evans has made 600+ WHP on 81.5mm blocks, so I think you'll be fine.
Old Jan 4, 2006 | 06:20 PM
Topdawgg's Avatar
Default Re: (tokes1320)
just thought with stock sleeves, i would wanna go as close to stock bore as possible
Old Jan 5, 2006 | 02:53 AM
Topdawgg's Avatar
bump... still lookin for more feedback
Old Jan 5, 2006 | 05:46 AM
blackeg's Avatar
you can go 81.5 no probs. i did because my block was sitting outside for about a year and had rust in the cyls. a little maching and its all good now
Old Jan 5, 2006 | 08:11 AM
Topdawgg's Avatar
i was plannin on runnin about 12-14 psi...
will it be fine with the bored out block
Old Jan 5, 2006 | 09:31 AM
asubennett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">i was plannin on runnin about 12-14 psi...
will it be fine with the bored out block</TD></TR></TABLE>
More than fine. I wouldn't ever run a STD bore on a block unless it was brand new from Honda. It is better to have a little thinner sleeves and a true straight bore than thick sleeves with an oval effect going on.
Buy some 81.5mm pistons bring them to the machine shop and have them bore out each cylinder to each matching piston. You won't regret the extra effort.
Old Jan 5, 2006 | 09:40 AM
dornon13's Avatar
Default Re: (asubennett)
[QUOTE=asubennett]
QUOTE]
EXACTLY...you will be fine with such a slight overbore
Old Jan 5, 2006 | 11:29 AM
Topdawgg's Avatar
ok guys... thanks alot.. i talked to my machinist, and he said that .5mm over the stock would get rid of the 2 bad cylinders..
so it looks like im gonna order a set of 81.5mm Pistons...
now the hard part... WHAT KIND? haha
Old Jan 5, 2006 | 11:38 AM
dornon13's Avatar
CP, wiseco, you cant really go wrong
Old Jan 5, 2006 | 12:01 PM
Topdawgg's Avatar
lookin for a set of wiseco as we speak.... thanks for all the help guys
Old Jan 5, 2006 | 05:29 PM
asubennett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">lookin for a set of wiseco as we speak.... thanks for all the help guys</TD></TR></TABLE>
No Problem. Happy Building!
Old Jan 5, 2006 | 05:32 PM
Topdawgg's Avatar
im pumped.. .this should be a good build
Old Jan 5, 2006 | 06:32 PM
blackeg's Avatar
wiseco's right here. 1500 miles no complaints.
LiLJisBooSTin89
Jul 8, 2014 07:32 PM
slowassBubble
Jul 1, 2011 04:57 PM
Skunk2R
Dec 28, 2008 04:56 PM
EKHB
Feb 14, 2007 11:04 PM
turbosi03
May 25, 2004 02:02 PM
