my foglights aren't working help!!
ok i need some help fast here !!i have a 96 sedan with stock square foglights that i put in about 2 months ago have worked wonderfully up until now yesterday i noticed they weren't working soo i got up went to school and now i have been outside for about 2 1/2 hours trying to figure out why they aren't working, i have my front bumper off and part of my dashboard off looking at everything i can to figure out whats wrong ,i checked the fuse on the foglight wiring,i check the bulbs which still seems to be good, i disconnected the plugs and pluged them back in but still nothing ,the relay switches over but can there still be a problem with the relay even though i hear it switch over ???is there another fuse im missing with all the other fuses ???i need some help here !!! thanks
__________________
Modified by jdmferiodrvr at 12:18 PM 1/4/2006
__________________
i had the sam problem i had to take the light apart and soder some wirees back on . before you do the check everything with a test light starting at the fog light and make sure your getting power
what do u mean by test light -(i think i know what u mean by test light)and thank u for being the only one to respond i such a long time !
Directly hook up each foglight to your battery to see if the problem exists with the foglights themselves. If they light up, then the problem lies within the wiring. Start from there.
The only way to do that would be to start cutting wires and **** to hook it up to the battery ,i really wanna stay away from that. The fogs wiring harness plugs into stock wiring that was already in the car .i made this quick diagram
You don't need to cut up your harness to directly hook it up to your battery. Get like a 4-5 ft piece of wire and connect one end to the battery and the other to the foglight.
